4 members (Nick in Manitou, Bill Hanlon, moparguy, Peggy M), 135 guests, and 0 robots.
Topics128,109
Posts1,056,269
Members48,439
#1344076 01/29/2020 12:42 AM
Ok on my 1949 GMC 150 I have ran into some confusion on which type of windlace my truck needs. The issue is it does not have a channel or any screw holes for the other style retainers. The cab appears to be all stock and dosent seem to have had anything done to it. I was told to look for any previous spot welds that would have held the channel to the cab but im a little confused on exactly what area they would have been. I see no spot welds that were on the i side of the cab. Only ones i have found in the perimeter were on the outside of the cab facing the door. I will include some pics. Thanks for the help guys.
My 54 has a channel not continuous but goes around the door .looks like they sell wind lace retainer but looks a little pricey .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Does your truck have the piece that goes along the floor horizontal.Rubber with a metal retainer.If you do I think they are a different style than the 50-55 first series
"The Journey"
Follow in the DITY
Yes I believe it does. I bought the truck in about 50 boxes and im down to the last of them and i did see the straight metal strips that go on the floor the length of the door.
I also looked and saw that they sell the aftermarket retainers. I just found it odd my truck does not even have the screw holes where they would have been previously attached.
Did you check your dash, does it have the holes as I posted previously? You can see it clearly in the picture above the top hinge pocket, there will be one on each side with the screw on versions.
https://www.flickr.com/photos/advance-design_parts_co/49456568082/in/album-72157631868452754/
Brad Allen to the rescue! The holes in the ends of the dash is the clincher for determining which type of windlace was original to the truck.
No holes here.
No holes then I would say no screw on trim, that screw location cannot be put in or taken out any other way, thus the holes.
Looks like another trip to that junk yard for some windlace retainer
"The Journey"
Follow in the DITY
So its gonna be something im gonna need to drill out spot welds on basically right?
This will be a difficult wrecking yard effort, there are numerous welds and the track is very thin gauge. For the time and effort you might want to consider the reproduction version.
Yea i will most likely just go with the screw on one. Not a big deal. Looks pretty straightforward.
Moderated by  ndkid275, Phak1
