5 members (dunfire, 55shaker, Rexville48, WICruiser, baldeagle), 104 guests, and 5 robots.
Topics128,014
Posts1,055,328
Members48,419
#13424 12/28/2003 9:02 PM
i have a 216 which runs good but i recently discovered a crack in the block would it be a good idea to weld it or get a new one and where would i get another one?
#13425 12/28/2003 9:18 PM
it depends on were the crack is if its not in a critacal spot and is not to big there is places that will weld them
also if you want a new one amercan classics has a wrecking yard whith old GM six block's wich are suposed to be crack free
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
#13426 12/28/2003 11:24 PM
With the cost of blocks for a 216, it isn't worth welding one. Personally, I'd put in a 235, but if you want to stay stock, put an ad in the swap meet and call some places around you for another block. Not too many people want the 216, so the cost of a block is somewhere at or above scrap value...
Fred
52 3600
69 C-10
#13427 12/28/2003 11:56 PM
There have been discussions on the board about 216 block cracks, down along the driver's side in the area of the frost plugs. The general feeling about these was that they were actually an area of corrosion and several people cleaned them up and sealed them with J B Weld. That seemed to be a solution.
1951 1 Ton Completed
#13428 12/29/2003 12:02 AM
My 45 truck had a crack like that, or corrosion pinholes like Truckernix describes.I added one of those tubes of Aluminum radiator sealer, problem solved for a few years until I put in a fresh 235.
#13429 12/30/2003 3:56 PM
Wleding cast iron can be tricky but worth it. Naturally, surface prep is important. Use a very hot arc but for very short distance. Overfill. after every inch, stop and release tension with a needle gun. This will last as long as original material. smile
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
