3 members (NJC, Wayne67vert, 1 invisible),
166
Mod | | | Forums66 Topics128,281 Posts1,058,471 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#13424 12/28/2003 9:02 PM | Joined: Dec 2003 Posts: 12 Member | | Member Joined: Dec 2003 Posts: 12 | i have a 216 which runs good but i recently discovered a crack in the block would it be a good idea to weld it or get a new one and where would i get another one? | | |
#13425 12/28/2003 9:18 PM | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | it depends on were the crack is if its not in a critacal spot and is not to big there is places that will weld them
also if you want a new one amercan classics has a wrecking yard whith old GM six block's wich are suposed to be crack free | | |
#13426 12/28/2003 11:24 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | With the cost of blocks for a 216, it isn't worth welding one. Personally, I'd put in a 235, but if you want to stay stock, put an ad in the swap meet and call some places around you for another block. Not too many people want the 216, so the cost of a block is somewhere at or above scrap value...
Fred 52 3600 69 C-10
#13427 12/28/2003 11:56 PM | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | There have been discussions on the board about 216 block cracks, down along the driver's side in the area of the frost plugs. The general feeling about these was that they were actually an area of corrosion and several people cleaned them up and sealed them with J B Weld. That seemed to be a solution. | | |
#13428 12/29/2003 12:02 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | My 45 truck had a crack like that, or corrosion pinholes like Truckernix describes.I added one of those tubes of Aluminum radiator sealer, problem solved for a few years until I put in a fresh 235. | | |
#13429 12/30/2003 3:56 PM | Joined: May 2003 Posts: 68 Member | | Member Joined: May 2003 Posts: 68 | Wleding cast iron can be tricky but worth it. Naturally, surface prep is important. Use a very hot arc but for very short distance. Overfill. after every inch, stop and release tension with a needle gun. This will last as long as original material.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
