8 members (68ironhead, jmoore, Joe H, Phak1, 55shaker, 3B, Waveski, 1 invisible), 74 guests, and 1 robot.
Topics128,154
Posts1,056,834
Members48,456
#1341965 01/13/2020 9:30 PM
I have a 1965 GMC fleetside shortbed truck that i have owned since 1977. I drove him for 6yrs and parked him. I have started restoring him by stripping everything down to the frame and rear end only. This frame has a leaf spring rear end. By the SN this is a 6 cyl -1/2 ton - 115" wheelbase - assembly plant Pontiac Mi - model code 1964-66 - gvw 5,0000 lbs. Looking in LMS and Brothers catalogs I can't find anything listing a 2 wheel drive truck with rear leaf springs. I have listed when I bought the truck to give a history of the truck. I knew of the truck for 3 yrs prior to buying and am relatively certain that it has not been modified. The shape it was in would not reflect anyones TLC having been applied( rough shape ). I need a bracket that bolts to the frame that the leaf spring bolts to left side front. I have seen cabs listed on ebay in Arizona that are rust free. Anyone know the name of junkyard's in that area. I have lots of questions but need to get this frame issue fixed before proceeding.
Welcome to the Stovebolt madness. There is no cure! shake
Be sure to ask your questions in the appropriate forum. Sounds like a bit of a mystery. Good luck.
Welcome to Stovebolt.Sounds like an interesting project keep us updated. See you around the garage forums and good luck.
Crusty Old Sarge
Crusty Old Sarge
Welcome to the Bolt, you should check in at the 60-66 forum those guys can answer all your questions. It's great to have another Southern Bolt on the site, stop in at the Southern Bolters forum as well.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Moderator
Moderator
2 Online: Content
Welcome to the Garage Neil !!
I also have a 65 GMC it's a one ton with the 292 inline 6.
Slight chance I may take it to the ODSS homecoming this year.
Read about the event here.
https://www.stovebolt.com/ubbthread...ing-2020-save-the-dates.html#Post1341542
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
Welcome aboard. Post some pics.
Welcome to the 'bolt.. I have many fond memories of the 66 GMC I used to have.
Another quality post.
Real Trucks Rattle
