| | | Forums66 Topics128,206 Posts1,057,433 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | Yup, Front and Rear disc brakes for 47-59 Chevrolet 3600 3/4 ton trucks for only $517.95 a set. At TSM MFG CO. INC
Check it out!! I am excited. Elmo
| | | | | Joined: Dec 2014 Posts: 357 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 357 |
Julian Carter
1970 Triumph GT6 1967 Triumph TR4A 1952 Chevy 3600 1948 MG-TC
| | | | | Joined: Sep 2013 Posts: 1,367 'Bolter | | 'Bolter Joined: Sep 2013 Posts: 1,367 | Interesting for sure. Just checked the site and the 47-59 3600 front axle kit is here.The rear axle kit here.
RonR
1951 3600 with Clark flatbed, T5, 4.10 rear 1970 340 Duster 1990 5.0 V8 Miata (1990 Mustang Gt Drivetrain) 1964 CJ5
| | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | Thanks Moparguy for posting the actual site and pictures on Stovebolt. I'm not able to. I appreciate your help.
| | | | | Joined: Apr 2008 Posts: 64 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 64 | Interesting kit. I didn't see what they recommend for master cylinder. Did I miss that on their website? | | | | | Joined: Mar 2017 Posts: 299 'Bolter | | 'Bolter Joined: Mar 2017 Posts: 299 | I'm kind of surprised not many 3600 3/4 ton truck owners are as excited about this as I am. Huh! Elmo | | | | | Joined: Jun 2010 Posts: 301 'Bolter | | 'Bolter Joined: Jun 2010 Posts: 301 |
1949 Chevy 3600 1975 W-25 Hurst Olds 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado
| | | | | Joined: Jul 2018 Posts: 238 Rustbucket Ranch | | Rustbucket Ranch Joined: Jul 2018 Posts: 238 | Nice! I'll have to keep this in mind when I swap over to discs on my '58 3800 | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Wow that is really amazing. I would think they would probably fit the 1 Ton. | | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | Will not fit duel wheel front hubs. This is in the ad towards the bottom. I guess single wheel applications only. But still nice to have an option.. | | | | | Joined: Nov 2018 Posts: 3 New Guy | | New Guy Joined: Nov 2018 Posts: 3 | Will not fit duel wheel front hubs. This is in the ad towards the bottom. I guess single wheel applications only. But still nice to have an option.. Yes there is one.....
TSMMFG-Disk Brake Conversion
| | | | | Joined: Jul 2019 Posts: 559 'Bolter | | 'Bolter Joined: Jul 2019 Posts: 559 | I dont know if my truck is a oddball or a fluke but my 3/4 ton has stock brakes on all 4 corners. Only aftermarket part is a dual master and that thing stops awesome. Im not sure i would ever need it to stop better. Its adjusted correctly and the pedal is nice and high. If i stomp that pedal your going into the dashboard if your not strapped in or holding on. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I have no problem with the operation of the brakes on my 1951 single wheel 1 Ton. The problem is finding replacement drums if you need them. Fortunately I am OK in that regard. | | |
