| | | Forums66 Topics128,082 Posts1,056,303 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | So I have some old gas in the tank. Been there at least 5 years. I have some ideas of what I am going to do with it but would like to know what the rest of you do with old gas. Or if you do anything?
Thanks Brian
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Our county solid waste relay stations takes it for free.
| | | | | Joined: Aug 2018 Posts: 1,004 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 1,004 | If it was me I would filter it into a container and it would be used for cleaning parts. Also if it’s clean enough I would add it to a nearly full tank about a gallon at a time. Also my Tractor would burn it no problem Recyclers is also a good option but less convenient. I’m not sure why folks r so afraid of old gas I have never had a problem with smelly old gas in any of my vehicles If everything is in good working order starting a machine on old gas seems to work for me just fine. But in Canada we have ethanol in the gas and that also seems to make it work better when aged compared to the original no ethanol blend. That ethanol is a free water scavenger I don’t get any water accumulating in my sediment bowls anymore which is nice. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | mix it with your lawn mower gas. ive used it from old vehicles that sat for years. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | mix it with your lawn mower gas. ive used it from old vehicles that sat for years. Don't do that with a recently purchased small Toro mower. It will void the warranty. | | | | | Joined: Aug 2001 Posts: 3,601 Moderator | | Moderator Joined: Aug 2001 Posts: 3,601 | I use it to clean parts. Ethanol free gas will last a lot longer than the 10% ethanol blend. To me, it is not worth the risk of gumming up a carb with varnish.
Just my .2% thoughts. Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Feb 2016 Posts: 1,990 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 1,990 | I use it to get my brush pile burning, I wait 'till there is snow on the ground to burn brush and a little "starting fluid" helps.
| | | | | Joined: Feb 2019 Posts: 4,486 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,486 | I ran it thru a gas filter and mixed it in the truck I use daily. I mix it less then 1 part to 10 and I never noticed any difference in the way it runs. I have also mixed it in the gas I use in my yard tractor with no issues.
I also use nothing but ethanol free gas in everything but my daily driver. I’ve cleaned too many carbs that the ethanol gummed up.
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I used antique gas in my 345 IHC, bent some pushrods when valves froze up, so be careful.
Ed
| | | | | Joined: Mar 2019 Posts: 1,003 'Bolter | | 'Bolter Joined: Mar 2019 Posts: 1,003 | | | | | | Joined: Aug 2001 Posts: 3,601 Moderator | | Moderator Joined: Aug 2001 Posts: 3,601 | Shhhh Glen! Don't let that secret out! Who needs a weed trimmer if you have a pump up weed killer.
And, Diesel fuel to seal a wood trailer bed. Don 1967 GMC 9500 Fire Ladder Truck"The Flag Pole"In the Stovebolt Gallery1946 2-Ton grain truck 1946 3/4-ton pickup, 1953 1-ton pickup 1957 1-ton flatbed dually, 1954 Pontiac Straight Eight Of all the things I've lost in my life, I miss my mind the most! | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Have any farmer friends? Works great to start a brush-pile fire.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | Whatever you do, don't dig a hole in the ground with a backhoe and dump a couple hundred gallons in it, and light it off. Not only will your neighbors complain of the sudden blackout of the sun, but so will most of the remaining residents of the county in which you live.
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | My problem sometimes was (is) old 2-stroke outboard gas. About 50 years ago, my brother-in-law took 5 gallons of old gas and used it in his Olds. That's when the gas:oil ratio was 25:1. He said the Olds burned oil anyway so more wouldn't hurt. 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Aug 2000 Posts: 248 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 248 | Awards go to practical solutions.....
Wash parts....
then recycle as weed killer.....a lot safer than 2.4.D or Round up....
Light up brush.....
mixed with rear end oil, engine oil, auto fluid, paint gun wash, will makes good water proofing for wood exposed to the weather or parts trucks that you store outside and anything left burns nicely dripped in the shop wood furnace....
Waste not want not
Now I will have to delete my home address...... guess I will just move the trailer....
Bob C. CMP Heaven The Hammond Barn
| | | | | Joined: Jan 2018 Posts: 189 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 189 | When I emptied the old gas out of the tank of my truck when I got it, I hoped it only had a couple gallons in it, but no it had like 12 gallons in it. I only had two 5 gallon cans, so it took me 2 trips to get rid of it. I had to take it about 6 miles across town to a shop that disposes of it by dumping it into their waste oil tank. The fee was only about $5, and I didn't have to deal with the stinky old gas that wouldn't burn anyway. | | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | Old gas, thinners, oils,solvents, etc.... They all go around the fence / and foundation perimeter . Havent had any ants, termites, spiders or crawlers in years.
| | | | | Joined: Jan 2018 Posts: 189 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 189 | Old gas, thinners, oils,solvents, etc.... They all go around the fence / and foundation perimeter . Havent had any ants, termites, spiders or crawlers in years. Probably nothing living in the ground water either. Sounds like more of a problem than a solution. | | | | | Joined: Sep 2019 Posts: 162 'Bolter | | 'Bolter Joined: Sep 2019 Posts: 162 | Go into business as a yellow jacket exterminator?
I invest my money in precious metals, mostly rust!
