7 members (TexasA&M48Truck, Bill Hanlon, Shade Baby, Nhluvstruck, Brian Moore, Wally / Montana, 1 invisible), 227 guests, and 2 robots.
Topics128,087
Posts1,055,985
Members48,430
#1341336 01/10/2020 12:22 PM
I found a 19-pin air needle scaler for sale online that I think might be just the thing to help me remove all the concrete-like road crud from the frame of my 1951 half ton I'm trying to coax into a street rod. The grease, mud and dirt has hardened into really thick, hard crud that's difficult to remove. Anyone have any experience with one of these and do they really work good?
Chuck
1941 Chevy coupe
1938 Chevy coupe streetrod
Work ok for smaller areas. But slowly. Very loud so wear hearing protection
1949 gmc 1-ton
A member here, Lugnutz, says the one he purchased at Harbor Freight worked very well on his crud......may check it out or ask him.
Moderator
Moderator
2 Offline
I have used them over the years in some of the jobs I worked at.
It should work good on that crud. It may also leave real little dimples in the metal.
Very loud and it should not used on body metal without a lot of care.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
They're good for removing slag from stick welding jobs. They do peen the metal, so if the surface finish is important, it might be a good idea to use a less-aggressive cleaning method like a cup brush on an angle grinder. Eye and ear protection are a must- - - -those flying pieces of crud can cause some painful injuries and the noise is hard to tolerate.
Crusty Old Sarge
Crusty Old Sarge
I have used these before on Military equipment with multiple layers of thick paint , grease and crud. They do a great job, just really loud and leave your hands buzzing for hours.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
I made a video showing how well a needle scaler works. A wire wheel or grinder can’t get in to corners, but a needle scaler can. VIDEO LINK HERE I mistakenly call it an air nibbler, but I meant needle scaler.
Sir Searchalot
Sir Searchalot
Been using it for years on frames and castings. I spray gas on the area while using it. The trick it to adjust the air pressure down. If you do that you won't get as much peening. Works very well in corners and an initial degrease effort.
Thanks for all the good replies fellas! Sounds like you all agree it’s a good tool. Thanks Lugnutz for the video. Really know what to expect now. I’ll be sure to buy good ear plugs too. LOL
Chuck
1941 Chevy coupe
62401
Double your hearing protection -- use plugs AND muffs. They are NOT kidding about the eye protection. Use goggles or something that protects from the side, bottom, top -- all around.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Thanks John! Will do!!!
Chuck
1941 Chevy coupe
I used one to remove the undercoating from the bottom of the cab of my truck, saved a lot of money when I had it media blasted. 3 things are really hard for the media blaster to remove - undercoating, sealer and body filler.
'66 C60 body, '97 C6500 chassis, '07 LBZ Duramax with Allison 1000
https://photos.app.goo.gl/cxwv1C6Ay2oxYH7u7
I used a vibrating multi-tool for removing undercoating from the cab floor. I used a serrated blade on it and it worked pretty well. That's another option for you, and you may already have one of those. I got mine from HF. link
Moderated by  MNSmith
