| | | Forums66 Topics128,087 Posts1,055,980 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2003 Posts: 27 Apprentice | | Apprentice Joined: Apr 2003 Posts: 27 | What is the cost of converting a 1996 caprice classic v8 from fuel injection to distributor/carbuerator.What pieces are needed. thanks---50 chevy 3100....
rrf
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I think a vortec, carb intake would work but you may want to talk to some techs at a GM dealership and find out for sure. You know the ignition is run off of the front of the crankshaft so I'm thinking you'll have to change the oil pump, at least, to run a conventional distributor. Also, the water pump is driven by the camshaft, so drive belts are going to be a problem too, Scott | | | | | Joined: Oct 2003 Posts: 363 Member | | Member Joined: Oct 2003 Posts: 363 | Should cost you less than $1000.
You will need an LT1 carbureted manifold about $260 for your L99 engine.
A carbutetor and a distributor.
All this is available through GM Performance Products. Call Scoggin Dickey and they can sell you the whole package. | | | | | Joined: May 2003 Posts: 328 Shop Shark | | Shop Shark Joined: May 2003 Posts: 328 | Why not just keep the fuel injection? You will make more horsepower, get better fuel mileage, and the engine should last longer.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
