10 members (JW51, Tinker5, TUTS 59, wilbur53, 3B, jupitor, GMCJammer51, J Lucas, walter74, dt235sd), 158 guests, and 1 robot.
Topics128,080
Posts1,055,952
Members48,430
#134146 04/09/2006 12:56 AM
Apprentice
Apprentice
What is the cost of converting a 1996 caprice classic v8 from fuel injection to distributor/carbuerator.What pieces are needed. thanks---50 chevy 3100....
rrf
#134147 04/09/2006 3:09 AM
I think a vortec, carb intake would work but you may want to talk to some techs at a GM dealership and find out for sure. You know the ignition is run off of the front of the crankshaft so I'm thinking you'll have to change the oil pump, at least, to run a conventional distributor. Also, the water pump is driven by the camshaft, so drive belts are going to be a problem too,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#134148 04/13/2006 5:45 PM
Should cost you less than $1000.
You will need an LT1 carbureted manifold about $260 for your L99 engine.
A carbutetor and a distributor.
All this is available through GM Performance Products. Call Scoggin Dickey and they can sell you the whole package.
#134149 04/14/2006 2:04 PM
Why not just keep the fuel injection? You will make more horsepower, get better fuel mileage, and the engine should last longer.
Never hold your farts in. They travel up your spine and into your brain...that is where crappy ideas come from.
