4 members (TUTS 59, Lightholder's Dad, klhansen, 1 invisible), 165 guests, and 0 robots.
Topics128,109
Posts1,056,266
Members48,439
#1341107 01/08/2020 10:44 PM
Went into my local O’Reilys to purchase a qt of brake fluid. The entire selection was synthetic! What are you guys using in your older vehicles? I was able to get non-synthetic 2 years ago to do my ‘62 C-10.
Been using the DOT 4 for some time. Never a problem. Its still stocked on the shelves around here.
2 Offline
i'm not sure what is meant by "synthetic" vs non with regards to brake fluid
however when it comes to substituting with modern products this is the rule
Dot 3, 4 or 5.1 brake fluid are all compatible and can be mixed to any ratio.
You will simply end up with a mix that is part way between the specifications of the two fluids.
example 1, vehicle states to use DOT 3, use any of the above, or a mix.
example 2, vehicle states to use DOT 4, use DOT 4 or DOT 5.1 or any mix thereof.
DOT 5 is silicone based, it CANNOT be mixed with the above, must use only DOT 5 for replacement fluid.
example 3, vehicle states to use DOT 5, only silicone type maybe used
I worked in a plant that made brake fluid in the mid 70's. All brake fluid on the market at that time was synthetic, some was labeled synthetic some was not. My preference is DOT 4 fluids that are labeled "low moisture activity" or something similar. Those have an additive that essentially neutralizes small amounts of moisture.
Harold Wilson
41 Chevy 3/4 Ton
I had to go out to my shop to see what I use. Valvoline synthetic 3,4
Craig
Interesting subject. I was looking for some brake fluid to put into my vehicles and I hope it was not DOT 5!
Another quality post.
Real Trucks Rattle
Rusty, all the dot5 I've seen is purple to help avoid mistakenly adding it to anything else.
RonR
1970 340 Duster
1964 CJ5
Been using DOT 4 forever too. Was sold on the fact that it has a higher boiling point and just better than lower numbered DOTs ; )
1954 3600
