6 members (55shaker, frogfarmer, Goach2, Otto Skorzeny, Peggy M, Hotrod Lincoln), 175 guests, and 4 robots.
Topics128,257
Posts1,058,015
Members48,479
#1340660 01/06/2020 3:06 AM
Hey, guys I’m considering a new project a 55’ 4100. My idea is to put 1/2 ton springs (altitude change). Leave the original 235,maybe a trans w/ a overdrive. My question is, right now the truck has nothing as far as a bed. Will a longbed fit or will I have to shorten the chassis.Im probably going to have to do a “C”notch. Sooo I need your knowledge. Thanx
chilwil86 #1340661 01/06/2020 3:13 AM
1955 1st or 2nd series (Advance-Design or Task Force - early or late 1955)?
What is the complete model number?
41XX what are the XXs?
tclederman #1340672 01/06/2020 4:42 AM
It’s second series 4100 she’s a duellie
chilwil86 #1340693 01/06/2020 1:12 PM
It’s not a 1 ton if it’s a 4100. Might want to consider moving this thread to Big Bolts.
chilwil86 #1340721 01/06/2020 3:46 PM
Offline
Offline
Completely different animal. You have a long, long road ahead of you to convert it to a pick-up. Find someone with a half ton and park them side by side. Get a tape measure and check the wheel stance, (front axle width) the spring length and width and the wheel opening of the front fender. Take a look at the rear cab mounts as well. Good candidate for the Cummins swap, but you'll need a rear axle. Motorhomes are good donors for axles. You can even find independent front suspensions that you can unbolt the entire assembly from the motorhome.
My 1955 GMC 450 Dump Truck
Elderly Iron
"Performance" is the pursuit of a toy that won't break.
chilwil86 #1340724 01/06/2020 3:55 PM
