| | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 50 | Hey, guys I’m considering a new project a 55’ 4100. My idea is to put 1/2 ton springs (altitude change). Leave the original 235,maybe a trans w/ a overdrive. My question is, right now the truck has nothing as far as a bed. Will a longbed fit or will I have to shorten the chassis.Im probably going to have to do a “C”notch. Sooo I need your knowledge. Thanx | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 1955 1st or 2nd series (Advance-Design or Task Force - early or late 1955)?
What is the complete model number? 41XX what are the XXs? | | | | | Joined: Aug 2011 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2011 Posts: 50 | It’s second series 4100 she’s a duellie
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | It’s not a 1 ton if it’s a 4100. Might want to consider moving this thread to Big Bolts.
| | | | | Joined: Dec 2006 Posts: 103 'Bolter | | 'Bolter Joined: Dec 2006 Posts: 103 | Completely different animal. You have a long, long road ahead of you to convert it to a pick-up. Find someone with a half ton and park them side by side. Get a tape measure and check the wheel stance, (front axle width) the spring length and width and the wheel opening of the front fender. Take a look at the rear cab mounts as well. Good candidate for the Cummins swap, but you'll need a rear axle. Motorhomes are good donors for axles. You can even find independent front suspensions that you can unbolt the entire assembly from the motorhome. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
