| | | Forums66 Topics128,165 Posts1,056,987 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2002 Posts: 102 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 102 | I have a Muncie 4 speed in my Pro Street 63 Chevy II and am wanting to change to a 5 speed. The engine is probably 400 plus hp. The car is a toy and only street driven. I'd like to change to a more modern 5 speed for the overdrive. I need someone to educate me on late model 5 speeds. What will work? S-10, Camaro, truck? Are they as strong as Muncie's? Do they direct interchange and fit early bell housings and clutches? I would appreciate any help here. Thanks.
Ron Thompson 51 Chevy 1/2 ton 36 F@rd coupe 65 Riviera
| | | | | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | Is this a troll post? Since when is a Chevy II a truck?
Anyways...
Might be complete overkill but you could use an NV4500. They're a truck transmission and can take the power you have.
Another option is the NV3500. It's not a strong as the NV4500 but it's stronger than a T5.
NV4500's can be found in chevy pickups. NV3500's can be found in Jeep TJ's. | | | | | Joined: Feb 2006 Posts: 395 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 395 | just my thought,,,if you are looking at the trans from a v6 to install behind 400hp is a mistake,,,,look at one from a HP corvette or something similer in HP... | | | | | Joined: Jan 2001 Posts: 613 Member | | Member Joined: Jan 2001 Posts: 613 | that will break a t5.you could get a six speed from a 93 up camaro or an aftermarket richmond trans. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | My vote is also for a tranny out of a late Camaro or Firebird. If you get the crossmember, bellhousing,flywheel and clutch from the same car it'll be a LOT easier to install. The more related parts you bring home,the more you have to choose from when you start fitting it together and need to adapt something. Don't forget to replace the pilot bushing-buy one to fit the tranny you're installing. Send your ol' Muncie to me. Speed | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Second dibs on the Muncie, Really would think twice before changing it. | | | | | Joined: Dec 2002 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 86 | Do a search on a Tremec 5sp Thats what i used on my gto. Bolt in set up
47.5 Loadmaster 5 window 48 Chevy 3600 69 GTO convertible | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 |
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Jul 2002 Posts: 102 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 102 | Thanks everyone. Can someone tell me about the Tremec 5 speed? What did they come in? Ray you said it was a bolt in in your GTO. Is this with a stock bell housing? Can I use my existing mechanical clutch linkage? Does the Tremec have internal shift linkage and is that a problem with shifter positioning? I'm wondering Ray, was this any problem in the Goat.Thanks again and I do appreciate the education.
| | | | | Joined: Dec 2002 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2002 Posts: 86 | Ron, I went with a aftermarket bellhousing and a hydraulic throwout bearing.But i don't think i had too.Shifter is internal. I got mine at Forte's Parts connection in burlington Ma. They have a website or you can give him a call. Great guy very helpful.
47.5 Loadmaster 5 window 48 Chevy 3600 69 GTO convertible | | | | | Joined: Dec 2003 Posts: 103 Member | | Member Joined: Dec 2003 Posts: 103 | Just a thought -- why not consider a gear vendors overdrive unit?. This will eimentate, clutch, presure plate, throw out bearing, linkage, and shifter location issues. The initial cost may seem high, but should be compareable to the cost of a 5 or 6 speed manual that will handle the power and torgue. Plus when you sell the car you can remoce the unit and drive shaft -- and use it in another vehicle. | | | | | Joined: Jul 2002 Posts: 102 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 102 | twe56,sounds like a good idea. Streetrod Builder Magazine just happens to have an article about the Gear Vendors unit. They say it's only available for automatics. GM's 350 and 400's only. Thanks.
| | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I just put one on my sm420. Call them and they will tell you if they can do it or not. Gearvendors.com | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | Keep that Muncie.. they are getting real hard to come by now...
| | | | | Joined: Jul 2002 Posts: 102 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 102 | Again, I thank everyone for your input. Bottom line, the reason I want an overdrive is so I can drive the car more. If you've read my previous post about this car, it's bad a$$ and a ball to drive. I thought with the monster cam in it, I'd be better off getting the rpm down. I'm really afraid of breaking valve springs. Again, it's bad a$$. I think I'll just drive it and have fun. If it breaks, I'll drive the truck. After all, I put the Muncie in it in 1979. I can't believe the Gear Vendors overdrive are as pricey as they are. I could build an engine for the amount they want for them.
| | | | | Joined: Nov 2005 Posts: 144 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 144 | In my neck of the woods, they're worth around $3K Canadian.
I'd rather buy an NV4500 for my truck. | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | RustyRod; Watch it,man-you're gettin' pretty generous with MY Muncie... Speed | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | do a search on 5 speeds. see a recent T5 questions thread. this has been covered but always interesting as more info floods in. This oughta keep some of you busy.... http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=006487 Other possibilies is the NV-1500 http://www.cyberjeep.com/products.asp?dept=5730 and NV-3500, http://members.aol.com/mymovie/motor/Jeep/swap.html S 542 FORD Borg Warner T-85N, http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=007235 http://www.6066gmcguy.org/3-to-4-speed.htm T10 - http://www.chevyhiperformance.com/techarticles/148_0305_t56/ , T18, T19, http://www.novak-adapt.com/knowledge/t18_t19.htm http://www.novak-adapt.com/knowledge/sm420.htm or http://www.motivegear.com/tech_info/tranny_guide/tranny_guide.html T-56 (Camaro 6 speed), http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=006487#000005 http://www.v8monza.com/images/tech/trans/monza-trans-5spd-Chuck_.jpg http://www.5speeds.com/muncie.htm The T5 I had built is an S~10 housing but has camaro V8 gears inside. T5's were origionally made for mustangs in 83 and 84 used in camaro's and firebirds. I believe that IS the best way to go w/ these T5's as borg warner made them w/ ALL completely interchangable parts. I have a better chance to handle any load and the HP [i]THE T5 WORKS ON MUSTANGS, JEEPS (4X4), CAMARO's && FIREBIRDS THAT HAVE HORSEPOWER !!!!!!!..... SO WHY WASTE THE $$$$ and BERATE THIS TRANNY and PUT IT IN YOUR TRUCK and BERATE IT AGAIN. WILL YOU NOT PUT IT IN AND HAVE IT WORK FOR YOU??? If you buy one from a four cylinder and it fails working in your truck ..... don't give it a bad name when these trannies work on autos that have way more Horse Power than your chevy does and still work. Do your homework first.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Am in the process of putting a TK0 600 in and found out that torque is what the suppliers are interested in, horsepower doesn't count much. With the high torque situation I have it required the TK0 600(600 ft lbs) and I'll add it's really pricey. I have heard rumors this trans might be in the late model supercharged stangs but would probably not be much cheaper from a salvage yard. After puking the whole bottom of the case on two rock crushers the price looks better and better.
Evan
| | | | | Joined: Jul 2000 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2000 Posts: 19 | There is an aftermarket company that tailors kits for a variety of cars. I think the name is Keisler Engineering. The cool thing is, if you need any sort of adaptor, they can provide it with the kit. They are NOT cheap, but they seem to have a really good sense of what needs to be done. They furnish instructions for the installation into your car. Not a bad idea, at least to investigate. I've been thinking about putting one into my wife's '69 Vette. But that's a few years off. By the Way . . . . . Is that Muncie an M20, M21, or M22??
Pat
From Sunny California Forever working on the '37 Under the shade of my dreams
| | | | | Joined: Jul 2002 Posts: 102 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 102 | How come everyone wants my Muncie? I only paid $100 for it in 1978! I thought that was kind of high.
