4 members (Peggy M, Jeff Ogden, cmayna, mk72), 46 guests, and 8 robots.
Topics128,012
Posts1,055,321
Members48,419
#1339529 12/29/2019 5:01 AM
Getting ready to add mud flaps to one of my trucks. The way the cross members on the flat bed are located, the mud flaps would just touch the back of the tires. I'll probably have to figure out a way to move them back some. How far back from the tires would be a good distance? My Bolt is stored off site and hard to get at right now or I would go look at that and measure those.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Rich'sToys #1339532 12/29/2019 5:25 AM
TGP Offline
Depending on the flaps you use touching while sitting isn't a problem.
The wind while driving will blow them back enough.
If not add a small cross plate bolted halfway up the flap with a small
Chain to the next cross member to pull them back a little.
That's Old School.
Tom
Rich'sToys #1339573 12/29/2019 3:55 PM
The distance from the ground is important too, Minnesota has regulations on that, I presume other states do too.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
Rich'sToys #1339580 12/29/2019 5:10 PM
Just use a stack of fender washers between the flap and the crossmember- - - - -5 or 6 of them will space it back 1/2" or so. A couple of strips of 1" wide aluminum flat bar 1/4" thick would do the same thing. Why is common sense so uncommon these days?
Rich'sToys #1339620 12/29/2019 11:50 PM
7
7 Online: Content
Length and distance from the tire will also come into play when backing the vehicle, if the tire can pinch the mudflap against a curb it will pull the mudflap off and depending on it's mounting could also damage fender/bracket/support points.
Not that uncommon, Jerry. My original question, if you'll recall, was HOW FAR back was far enough? If 1/2" is all I need, no problem! If I need more, then I'll come up with plan B.
This truck isn't going to be used that much. The flaps are mostly for aesthetics.
Rich
1947 Loadmaster
