| | | Forums66 Topics128,119 Posts1,056,311 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2018 Posts: 298 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 298 | Hey Bolters, anyone have a picture of where and how the return spring goes. Mine were both missing. Thanks Bill
1937 GC
| | | | | Joined: Dec 2019 Posts: 439 'Bolter | | 'Bolter Joined: Dec 2019 Posts: 439 | just got a 37 and have same question. starting to tear down and having a heck of a time with those clutch head screws.
Larry Old man᠁Old truck᠁neither one goes very fast. All you need in life is TIME, PATIENCE and MONEY. If you are missing one component, you'll need an abundance of the others two.
| | | | | Joined: Jan 2018 Posts: 298 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 298 | Be prepared for some work. I bought a set of clutch head sockets and it worked on some and not on others. Sprayed them up with kroil, let them set and tried again. One I could get a vice grips on also came out. Sometimes it helps to tighten a little bit first then back out. I am just about done with my truck after 2 years of work. If I can be of any help feel free to private message me or email. If you get inside the door and can see how the handle return spring is mounted please take a picture for me. Good luck, Bill
1937 GC
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | The key to removing old rusted clutch head screws starts with Bill's advice above. Get the proper size clutch head drivers and use a penetrating oil, like Kroil. Also, be sure to take a sharp tool, like an awl or ice pick, to clean out the old rust and crud from the head. The sides are straight and if you clean them out the driver will remain in place and you can place maximum torque on the hardware. Much better than slotted screw heads or phillips, in my opinion. Some are so rusted that you break the head off. That is not the fault of the design of the hardware, just Old Man Rust winning a skirmish. Kent | | | | | Joined: Sep 2010 Posts: 1,707 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,707 | Impact drivers are your friend in removing clutch head screws. Tighten them just enough to make them move and break the bond. I used my pneumatic hammer with a clutch head tip welded on. I also added a screwdriver welded to it as a handle to help turn the tip. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Feb 2010 Posts: 323 'Bolter | | 'Bolter Joined: Feb 2010 Posts: 323 | On mine the only springs are in the lock itself and a small one on lock release arm. I found some clutch head bits for a nut driver and ground them flat to keep them sharp. Kroil is the best for sure
1937 Chevy 1/2 ton panel 1953 GMC 2 ton. future car hauler
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | .......ORIGINAL QUESTION: Hey Bolters, anyone have a picture of where and how the return spring goes. Mine were both missing. Thanks Bill Bill, sorry I can't get to mine right now. If you don't get an answer pretty soon let me know and I'll go pull mine..
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Bill, The only spring I am aware of is internal in the door latch. What spring are you asking about?
Kent | | | | | Joined: Jan 2018 Posts: 298 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 298 | The handle return spring that keeps the handle level. I found nothing on mine when they were disassemble. I do have new springs but no way of knowing how the mount.
1937 GC
| | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Bill, There are no externally visible springs on the door mechanism. The spring that returns the latch and holds the handle level are internal to the latch box. So you are saying you have disassembled the latch itself and there is no spring?
Fortunately, both my latches function normally, so I have never taken the latch box itself apart. Thus, I can't help you with your question.
Kent
| | | | | Joined: Jan 2018 Posts: 298 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 298 | Thanks Kent, I have not taken the box apart so I guess that's why I seen no return spring. Bill
1937 GC
| | | | | Joined: Jan 2018 Posts: 298 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 298 | Hey, kinda good news!! Found pictures of door latch on Jim Carter site to repair sagging door handles on 39 to 46 trucks. Hope my 37 is the same or close and can get repaired. Will be taking pictures of mine in near future if any one is interested Thanks to all for your help. Bill
1937 GC
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Bill I haven’t taken my ‘37 door locks off, so can’t offer any specific help with your questions. However, I have done so with my ‘46 and replaced the springs. Here is a photo of the door lock on my ‘46 Chevy 1/2, after replacement of the “anti-droop” spring. It appears from the 1929-1946 Master Parts Catalog the locks are different between the two. The spring shown was sold by Jim Carters. FWIW, the handles droop on my ‘37 as well. I don’t know if that is typical or not. [img] https://www.stovebolt.com/ubbthread...DEE0123-1F80-454E-9BF6-F691BF4F637A.jpeg[/img] | | | | | Joined: Jan 2018 Posts: 298 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 298 | Sparky, thanks for the.pics. Hope to get it looked at in the next few days. Setting up a 1927 metal lathe in my garage with overhead line shaft. Bill
1937 GC
