0 members (), 93 guests, and 2 robots.
Topics128,167
Posts1,057,021
Members48,458
All the valve covers I have ever seen are held down with the 2 acorn nuts. Has anybody ever seen one that used the 4 hold down bolts on the later 235/261's? I'm going to make my own and I think they're in the way. Any pic's of custom or aftermarket ones are appreciated.
Curt B.
You Tube
Try Offyparts
They list two different Valvcovers for those Engines (also with different prices :rolleyes: )
One for Chevrolet: 1937-53 235-261 Valve Cover (1036)
and the other one for: Chevrolet: 1954-62 235-261 Valve Cover (2731)
So I think the later one is with the bolts on the rim.
Unfortunaly the have no pictures. So you have to call or drop them a line.
Please let me know if you found out the difference between those two covers. I want to buy one for my 261.
Frank
The offy valve cover for 235 and 261 uses the 2 center bolts as the 216 does. They send longer studs that go thru the rocker stands. I bought a new on in the late 70s and that is what offy sent.
Thank's for the link Stovebold. It does give me more ideas. That rules out Offy. All others seem to have the 2 holes in the top. i don't even want an oil fill in mine. Wayne,Edmunds,Clifford,Fenton, etc. all seem the same. Has nobody made one using the 4 bolts?
You Tube
Junior Member
Junior Member
I bought the polished aluminum Wayne valve cover and side cover from Patrick's a couple of years ago and installed on my 235.
The studs were simple to install, and real positive bolt down, no leaks.
Suggest you use the 216 valve cover gasket. You will likely need to make or get a spacer to install between the head and the thermostat housing. An option might be to shave the rear of the thermostat housing (it may not be thick enough to get claerance this way). This is necessary because the thicker aluminum cover fits the OUTSIDE perimeter of the original flanged cover.
I think PES makes what you want. Santucci's book on the L22 inlines has a picture of one.
1954 GMC De Luxe COE
I took the paint off my original, sanded it to a shiny raw metal finish and had it powdercoated with a high temp clear coat for $20. Mine has the chevy script which I like, but I believe there are originals of different years with no script. Just an idea.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
