8 members (NJC, cmayna, Hotrod Lincoln, lumbersawyer, JW51, 3B, cshades, 1 invisible), 100 guests, and 6 robots.
Topics128,064
Posts1,055,860
Members48,428
#1335670 11/28/2019 10:41 PM
I've bought two different flywheel covers and neither one fits. The last one I got has the cutout for the bellhousing mounts but the rear tab won't clear the oil pan to seat. Is there a certain way it can only go on? A picture perhaps. 1960 261 3 speed. Any help is appreciated.
1958 Chevy Grumman Olson step van
Chaz 58 #1335675 11/28/2019 11:51 PM
Do you have a picture of an original?
Another quality post.
Real Trucks Rattle
Chaz 58 #1335691 11/29/2019 2:11 AM
No, I wish I did so I know what to look for.
Chaz 58 #1335702 11/29/2019 3:25 AM
Riding in the Passing Lane
I have had to trim a little metal off of them before.
George
1972 Chevy c10 Cheyenne Super
Chaz 58 #1335719 11/29/2019 6:51 AM
Not sure of years as there are some notched and others not. The flat upper installs first.
https://www.flickr.com/photos/advance-design_parts_co/8129369624/in/album-72157631868452754/
Chaz 58 #1335740 11/29/2019 3:47 PM
Are the V-8 and IL-6 covers interchangeable?
Real Trucks Rattle
I'm not 100% sure but do not believe they interchange due to different bellhousings on 216/235/261 and the V8 and later sixes. A study of the later Master Parts List books might help in determining if the same part number carries across from 216/235/261 to later engines.
I've also met similar looking pans with different (and incompatible) profiles on the joint line between upper and lower segments.
Chaz 58 #1335912 11/30/2019 11:01 PM
I was surprised to find there were more than two kinds. The repops are often marketed as universal fit.
Chaz 58 #1335917 12/01/2019 12:04 AM
It's been my experience that nothing from the V-8 engine (and 63 up 6 cylinder) and bellhousing will interchange with the 216/235/261 series engine/bellhousing. One exception would be some of the clutch release forks.
Fred
Chaz 58 #1335949 12/01/2019 12:47 PM
There are early and late versions of the flywheel cover. The change occurs somewhere around when the 235 got insert bearings.
Lots more pictures
Chaz 58 #1335975 12/01/2019 4:17 PM
Here is my list.
Chevrolet called them "underpans".
The front vertical part is called "extension".
This is a six cylinder list only.
Flywheel Under pan 0.679
1937-48 Passenger 839335
1949-62 Passenger 3688221
1937-53 truck 838438
1954-55 1st truck 3702830
1954-62 truck (1954-55 1st, w/HD clutch) 3725088
Extension
1937-39 Passenger 838484
1940-48 Passenger 839131
1949-54 Passenger 3688218
1955-62 Passenger 3836317
1937-39 truck 838483
1940-62 truck 839180
My Blog
Chaz 58 #1336080 12/02/2019 1:14 PM
Interesting, I need one for my late 50's 261 as well.
-Patrick
1953 Chevrolet 3100
261 / 4-speed / 4:11 / Commercial Red
Chaz 58 #1336117 12/02/2019 7:42 PM
Z
hmmm.
hmmm.
Z Offline
It is a two piece I think.
Chaz 58 #1336456 12/04/2019 10:54 PM
The one I need has cutaways on each side and a crescent cutaway up front. I have a picture in truck parts wanted.
