| | | Forums66 Topics128,036 Posts1,055,461 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I've bought two different flywheel covers and neither one fits. The last one I got has the cutout for the bellhousing mounts but the rear tab won't clear the oil pan to seat. Is there a certain way it can only go on? A picture perhaps. 1960 261 3 speed. Any help is appreciated.
1958 Chevy Grumman Olson step van
| | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | Do you have a picture of an original?
| | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | No, I wish I did so I know what to look for.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I have had to trim a little metal off of them before. George
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | | | | | | Joined: Dec 2002 Posts: 3,439 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,439 | Are the V-8 and IL-6 covers interchangeable?
| | | | | Joined: Dec 2010 Posts: 97 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 97 | Are the V-8 and IL-6 covers interchangeable? I'm not 100% sure but do not believe they interchange due to different bellhousings on 216/235/261 and the V8 and later sixes. A study of the later Master Parts List books might help in determining if the same part number carries across from 216/235/261 to later engines. I've also met similar looking pans with different (and incompatible) profiles on the joint line between upper and lower segments. | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | I was surprised to find there were more than two kinds. The repops are often marketed as universal fit.
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | It's been my experience that nothing from the V-8 engine (and 63 up 6 cylinder) and bellhousing will interchange with the 216/235/261 series engine/bellhousing. One exception would be some of the clutch release forks. Fred
| | | | | Joined: Nov 2011 Posts: 1,610 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,610 | There are early and late versions of the flywheel cover. The change occurs somewhere around when the 235 got insert bearings. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Here is my list. Chevrolet called them "underpans". The front vertical part is called "extension". This is a six cylinder list only.
Flywheel Under pan 0.679
1937-48 Passenger 839335 1949-62 Passenger 3688221
1937-53 truck 838438 1954-55 1st truck 3702830 1954-62 truck (1954-55 1st, w/HD clutch) 3725088
Extension
1937-39 Passenger 838484 1940-48 Passenger 839131 1949-54 Passenger 3688218 1955-62 Passenger 3836317
1937-39 truck 838483 1940-62 truck 839180
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | Interesting, I need one for my late 50's 261 as well.
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
| | | | | Joined: Sep 2011 Posts: 58 hmmm. | | hmmm. Joined: Sep 2011 Posts: 58 | It is a two piece I think. | | | | | Joined: Oct 2012 Posts: 307 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 307 | The one I need has cutaways on each side and a crescent cutaway up front. I have a picture in truck parts wanted.
