| | | Forums66 Topics128,074 Posts1,055,914 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Hey folks, when installing a new dual master cylinder(under the floor of '48 1/2t, SB, chevy)and install new brake lines, do you ,can you order pre-bent lines for the front and rear or do you bend your own ? If pre-bent lines are available , does any body have the part numbers ? I have all new wheel cylinders and flex lines goin to the wheels , just need the hard lines 3/16" and 1/4". Thanx :confused: | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Had to bend my own. Especially if you have made any modifications to the original, such as IFS, or more modern rear. | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Yes sir coach-frank, I'm installing 5 lug disk in the front and newer open shaft 10 bolt in the rear with new dual master cyl. so I guess I'll be a bending. Thought about using a newer model truck like a '72 sb 1/2 t because thats when they first came out with disk brake front ends ? and the frame length is about the same. Maybe someone has done this and will clue me in. Thanx BTW Great truck on your site!!!!!!!!!!!!!! | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Bent my own too. Make sure you use a good, name brand double flare set to make your ends. Get a good bender too. Good luck, Scott | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | I have a good bender , but its the person behind the bender I'm not sure about. Looks like a rocket scientist will have to understand the instructions.........Maybe thats why I never became a trim carpenter. lol
Scott , u picked up a sweet deal on your '48 . looks great | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | I bought the already made stock w/ double flares. They come in 8'' to 60''. bent them up and cut where needed. Then took them to a brake shop w/ one of those $400.00 double flaring machines. W/in 5 minutes they had flared all my new one ended pipes and I was ready to install them on the truck. NOTE: I also bought long (about10'') springs (@ .30 each) from a surplus steel shop and stretched them longer (about 24'') and slipped them over the brake piping b4 the ends were re-flared. It helps protect the piping from rocks and looks good. mounted them all w/ rubber holders. the brake shop told me they charge $12.00/ft for the same.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Nov 2005 Posts: 3 Junior Member | | Junior Member Joined: Nov 2005 Posts: 3 | Here's a Question that may be dumb. I have noticed that stainless brake lines are a lot cheaper at boat trailer suppliers. Is it safe to use their lines in my 53 1\2ton | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Hey Jim, I was just getting ready to ask you what the reason was behind those springs? didnt know if it was for cooling or looks or what? Can you tell me if when I come off of the prop. valve do I need all of those spirals , because if that is for looks , where I'm mounting mine only the road and rocks could c-it. lol I will definately use the springs on mine. Thanx 4 tha help . everybody.
JTEAL2345 I have heard that a lot of things are cheeeper at those suppliers , like pressure hoses and brake lines, but I forget about them when comes time to buy them. I dont visit them as much as the auto parts folks, but the lines should be the same if not stronger so you won't have to row back in.( kinda like aeroplane parts)I wouldnt want one to break on me up there. Good day and welcome to tha BOLT | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | Hey Bow no not for cooling but just rocks. @.30 each I just couldn't go wrong, besides the brake guy and two other catalogs sell them for big $$ bucks.
Remember: when you do the rear axle's piping KEEP the 3/16'' lines behind the axle (to the rear) so when the tow truck guy shows up w/ his big nasty hook and puts it around the axle, it does not foul/crush the brake line. The front will get hiden inside the cross member.
| | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Thanx Jim, I will remember that. Hopefully if there is a need for that , I'll be there to instruct tha fella where to place his hook! lol I kan only hope that it's not a f**d tow truck! Hard to live that down. c-ya , Mike | | |
