2 members (cmayna, Wickedbass),
71
Mod | | | Forums66 Topics128,086 Posts1,056,101 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | The engine sits level in my 37 and with a later 235 the carb leans towards the front,was there ever a 235 that sat level in a big truck or industrial application that would have a intake where the carb would be level. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I do have a 37 intake that I can have the ports machined larger. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It seems you could take one of those plastic spacers that go between the carb & manifold & grind it at an angle. You may have to elongate the holed in the carb a little.. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | The present 235 is from a truck and it it does anglr the carb some but the new 235 is from a 60 car and looks to have more of a angle but could be a illusion. | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | If it tips forward, that would mean the fuel level in the bowl would be closer to level when you are drag racing due to centrifugal force  Joking aside, a number of companies over the years have produced wedges for marine engines to level the carburetor. Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Feb 2004 Posts: 29,795 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,795 | When I'm fabricating motor mounts I put a carpenter's level on the intake manifold carb flange and level it both ways. Of course, the suspension needs to be close to its normal running height, front and rear. If your engine is already installed it would be simpler to machine the top of the manifold to correct any out of level problems. Jerry
| | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I might put the front of the engine up a little. | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Is it giving you any kind of trouble or just the looks bother you? We also mount them according to the carburetor flange but I tell the customer to take a picture because unless they live in the flat lands of western Kansas, Nebraska, or along the Gulf Coast it will be the only time it will be level again. Cars ran from 1900 to 1987 in San Francisco with carbs that were never level. Stick a wedge under it if the sight is making you have headaches. WW1 dogfights would have been very boring if both planes had to stay level.
Evan
| | | | | Joined: Dec 2018 Posts: 473 Shop Shark | | Shop Shark Joined: Dec 2018 Posts: 473 | I was under the impression that aftermarket dual plane intakes manifolds were designed with a taller profile at the rear to compensate for engine angularity...etc. | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I had to do some modifications to the carb to get fuel in the pump area and that was when the truck sat even,now the truck sits lower in the front and if I can just get the carb to sit lever with the engine it would be nice. I think around 1940 the engines sat lower in the rear. | | | | | Joined: Jul 2000 Posts: 2,193 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,193 | Cars ran from 1900 to 1987 in San Francisco with carbs that were never level.  Yes, but they ran better downhill.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | |
