5 members (diseasel, Bill Hanlon, 59 fleet, Phak1, Wayne67vert), 109 guests, and 1 robot.
Topics128,035
Posts1,055,566
#1335007 11/23/2019 9:34 PM
I'm in the camp of wanting to maintain originality as much as possible but want to incorporate some things that promote engine life & performance. The vacuum windshield wipers are one feature I'd like to keep (not a daily driver but a Sunday driver). That being said, does a PCV system such as Deve's have a significant affect on the vacuum wipers?
1965 Chevy C10 Longbed Fleetside
Nothing but bad stuff can happen with that system. A factory PCV was used with vacuum wipers on a lot of vehicles. If you want to be period correct and still have good working wipers try to find a dual action fuel piump that works. Of course, finding one of them might be akin to discovering the Holy Grail, an homest politician, or a truthful used car salesman!
What year/make truck?
1951 1/2 ton
I found one of those fuel pumps at the Stovebolt Reunion.
1954 Chevy custom 261CID, T-5 5 Speed.
1952 Chevy 6400 2 ton hydraulic flat bed.
double-action fuel pumps (metal top - if a glass bowl style was available, it will be harder to find):
Jim Carter
Classic Parts
The Filling Station
here is one with a glass top - how deep/heavy is your pocketbook/wallet?
Thanks for the advice
Go for the look, keep the hoses intact .........replace the vacuum wiper motor with electric nobody will ever know. Plus you’ll actually have wipers on the rare occasion you might need them.
Electric wipers are on the top ten hidden mod list...........for obvious reasons.
"I'm in the camp of wanting to maintain originality as much as possible . . . "
Original appearance or original-working equipment?
Dual-action vacuum wipers work well at all speeds/rpms.
They do not care about 6v/12v or pos/neg ground.
AD Addict & Tinkerer
One more thing to consider if you decide on electric wipers, is the cheep ones sold on eBay interfere with the choke cable. You have to buy the more expensive ones such as Newport Engineering to be able to install without issues.
Phil
Project Journals
Stovebolt Gallery Forum
...Phil is right on.
Insomniac
Insomniac
My truck came with the factory PCV system and vacuum wipers. Standard fuel pump - not dual action.
When I installed the power disc brakes, I replaced the vacuum wipers with electric and ran the vacuum line to the brake booster.
So, yes, you can run PCV and vacuum wipers.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
V
V Offline
I ran a PCV on my old 216 with vacuum wipers and just a std fuel pump, no additional vacuum and it was serviceable for the several years I ran it that way. I rarely ventured out in the 49 if it was already raining but when caught out on a cruise the vacuum wipers had no trouble getting me home safely.
I did a thread and review on it many moons ago, (2013 or so I believe). I tried Deve's way and ended up modifying the draft tube to position the PCV further away from the block as my old 216 had way too much blowby to mount the PCV directly in the block.
The size of the PCV matters immensely as too big will rob too much vacuum from the wiper motor. I replaced the 216 with a 235 and will be installing the old PCV setup to the 235 once I clean it up and make it more presentable. Too many benefits to running a PCV IMHO.
Good luck.
Hey Volfandt Thanks for the advice.
"....and will be installing the old PCV setup to the 235 once I clean it up and make it more presentable" - you mean a factory original PCV system?
