6 members (Paul_WNC, Gdads51, Shardean, Greg_H, NorCal52Suburban, Waveski), 60 guests, and 6 robots.
Topics128,021
Posts1,055,357
Members48,420
#133412 12/12/2005 2:06 AM
Junior Member
Junior Member
Alright, how much of a difference does your IFS conversion really make???
I have a 38 3/4 ton Pickup and I'm up in the air about the front suspension. What I was planning on doing was keeping the org, leaf spring and solid frt axle. I will replace the org. knee action shocks with high quality modern ones(Im thinking edelbrocks), replacing all rubber bushings with polyurathanes, and adding an anti-sway bar. How do you think this will compare against and IFS system?
#133413 12/13/2005 6:00 AM
Well, an IFS will handle much much better. When one wheel hits a bump on a straight axle it affects the whole thing, but on IFS, only that wheel is affected.
Straight axles can handle the biggest loads, which is why I decided to stay with mine instead of going forward, which would have changed my 1 ton rating. This is why the big trucks still have straight axles and king pins.
All the mods you suggest will help, but its a pretty big leap forward to get to IFS.
#133414 12/21/2005 10:19 PM
I went with the IFS,there is no comparison,between that and a straight axle,for handling and ride.It all depends on what you want,and how you intend to use it.Mine is used strictly for shows,cruisins,and an occasional ride.I have had a couple of street rods with dropped front axles,newer shocks,better bushings,etc.but they still rode rough and steered hard.I think IFS is the only way to go,but then thats just my opinion.
#133415 12/21/2005 10:33 PM
I have a dropped axle, modern tube shocks, factory sway bar (off a panel), radial tires, restored stock spings, shackels etc, drives and steers great. In my 46 half ton.
1946 1/2-Ton Chevy
#133416 12/22/2005 2:38 PM
I guess it depends on how smooth is smooth enough.
Do you want it smooth enough for you to ride in all day;
or smooth enough for the ol' lady to ride with ya?
I plan to save some money AND get some peace and quiet...
Cheers,
mark.
'51 KY 3100
#133417 12/28/2005 9:23 PM
How much difference probably depends on how you plan to drive it, and where you plan to drive it. If you are going to drive nice on paved roads you may never be able to tell the difference.
The key to making a straight axle ride and drive nice is making sure the entire suspension is in good condition. Don't swap to an IFS just because your straight axle suspension is worn out.
#133418 12/29/2005 6:09 PM
i've always liked the straight axle...just plain and simple.
1966 Chevrolet C-10
1971 Chevrolet Camaro RS
1989 Pontiac Bonneville
MY GARAGE...www.dragcitygarage.com
#133419 01/19/2006 4:09 PM
ODSS President
ODSS President
MAC, what kind of driving/hauling are you talking about. Are you ready to put more money into your truck than you did for it's initial purchase? I hear of guys doing this all the time and only bring their rides out in good weather.
I improved the ride dramatically with tube shocks, king pins, sway bar, and of course RADIALS. I haul a bit so I use LT 215 85r 16's, I assume a more comfortable ride can be had using a P tire. Incidentally, I am a daily driver of a '49 3100, '56 235, 1-hw, Fentons, '62 3sp+od, '57 3.90 rear. I have travelled in excess of 1500 mile round trips a few times.
I'm with chevyman on this one.
~ Cosmo
1949 Chevy Half Ton
#133420 01/22/2006 8:58 AM
I kinda figure If you want soft-n-cushy,you should drive a car. I like my rough ridin',sloppy steerin',build your arm muscles up ol'trucks. And granted,IFS will help your handling,but really,you aren't goin' road racin' in it,are ya?(Actually,even my worn out ol' trucks aren't THAT hard to drive)
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
