Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (klhansen), 116 guests, and 5 robots.
Topics128,275
Posts1,058,571
Members48,492
The C60 has a straight 6 minimal cab rust and a manual the smaller has a 350 and a TH400 but some rust under the door and on the fender. Both are flatbeds. Same color. Same Price
Which would you pick? I prefer the 350?
1 Offline
Same cabs or different?
Same Cabs, photos linked. The one with red wheels has rust on fenders, grill, and under the doors but it has a 350. The black wheels has a 235 and 4 speed
Black Wheels
Red Wheels
R Online: Content
You may have to get both!! grin
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Rust is hard to repair and probably worse than you see from the outside. Bodywork and welding takes real skill plus paint is expensive too. A 350 with a TH400 is easy to find on Craiglist or elsewhere and an easy swap. My vote is for less rust. Also you can sell the original drivetrain to recoup some cost. All just my opinion!
I would have to agree with the no rust option, I am no body man but an engine swap is easy for me. It's your truck so you get to decide. If you do decide on the swap route, fire the 6 cylinder and sell it from the truck, that will be much easier than pulling it and saying "it should run..." while it lays under a tarp.
Mac :{)
1962 K10 short step side, much modified for rally
1969 T50 fire truck, almost nos, needs a few things
These 2 trucks are different models. The one with red wheels is a 3800 1-ton. Probably has 18" wheels, maybe 16". The GVW is less than 10,000. The 2-ton, probably a 6100 model (not C60) is 14,000 - 16,000, and has 20" wheels with a different bolt pattern. You should compare the information on the identification plates of each truck. And decide what you want/need the truck to do.
Professional Novice
Thanks for the info, the 3800 with the red wheels are 19.5” with 10 year old tires. Both will have about 1.5 tons on the flatbed for promotional use.
Crusing in the Passing Lane
The 6100 wheels are 5/10 on 7.25, can fit modern 19.5 or mid '50's 22.5 wheels.
Ed
Ed, the 6100 pictured has 6-lug Budd's...
Check the wheels, they might be 22.5" tubeless which is better than the 20" tube type.
Also, check the engine...it should be a 261. The 235 was not factory installed in the 6000 series trucks.
Make sure you look both of the trucks over very carefully, they have both been repainted and that can hide lots of bad stuff. The TF trucks love to rust above the windshield (inside and out), front and rear cab corners, door bottoms and the cowl air plenums (stick your head in the wheel opening and look back towards the door).
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Pardon, I misjudged the red ones, they are 8 on 6.5.
Ed
Thanks, I think I am going to pass on the red wheels with all the rust. It’s on 19.5s and the tires are also from 2010. The seller tried to claim “new tires” lol. I also have a 1953 Dodge B series dually. 89 Humvee 06 C6 and 80 Z28 an 08 Tahoe hybrid, I think the 6100 would fit in, id like a 454 in it or a LQ4. Duramax is too much work to swap.
