9 members (lumbersawyer, sparky46, LAROKE, Otto Skorzeny, Gdads51, Woogeroo, Shade Baby, 68ironhead, Jon G), 143 guests, and 1 robot.
Topics128,104
Posts1,056,197
Members48,436
#1333281 11/11/2019 4:27 AM
Hello, what a great site! I've picked up some great info even before joining. 3 weeks ago I bought a 1946 PW. Luckily, it appears almost completely original and is rust free.
I have a couple questions.
1. What engine is this? Engine stamped "DEA70589"
2. There is a spacer under the carb that has a vacuum line run to it from the carb. There is a butterfly in it that appears to be actuated by some mechanism inside of it. What is it and what does it do?
Pat
1946 PW Grain truck, 1966 C10 long stepside, 1972 C20 Custom Camper Big Block, 1975 C10 Silverado OE big block.
Welcome to the Stovebolt madness. There is no cure! Questions are better asked in the garage forums. shake
How about some pics to get things started.
The thing under the carburetor is a governor. It can limit the speed of the engine and the vehicle. Most often found on commercial and military trucks. It's adjustable.
D is the letter code for 1946. I'm not sure about the rest.
Professional Novice
Thanks. I'll repost in the shop section. I'm trying to figure out how to get the pics on a server...
Welcome to the Stovebolt. See you around the garage forums.
Welcome to the 'bolt. You can find the instruction on posting pix in the left hand column.
Another quality post.
Real Trucks Rattle
Thanks, got it.
