0 members (),
80
Mod | | | Forums66 Topics128,266 Posts1,058,385 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2019 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2019 Posts: 40 | Hello, what a great site! I've picked up some great info even before joining. 3 weeks ago I bought a 1946 PW. Luckily, it appears almost completely original and is rust free.
I have a couple questions. 1. What engine is this? Engine stamped "DEA70589" 2. There is a spacer under the carb that has a vacuum line run to it from the carb. There is a butterfly in it that appears to be actuated by some mechanism inside of it. What is it and what does it do?
Thanks, Pat
1946 PW Grain truck, 1966 C10 long stepside, 1972 C20 Custom Camper Big Block, 1975 C10 Silverado OE big block.
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Welcome to the Stovebolt madness. There is no cure! Questions are better asked in the garage forums.
| | | | | Joined: Dec 2018 Posts: 473 Shop Shark | | Shop Shark Joined: Dec 2018 Posts: 473 | How about some pics to get things started. | | | | | Joined: Nov 2000 Posts: 1,975 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,975 | The thing under the carburetor is a governor. It can limit the speed of the engine and the vehicle. Most often found on commercial and military trucks. It's adjustable.
D is the letter code for 1946. I'm not sure about the rest.
Professional Novice
| | | | | Joined: Nov 2019 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2019 Posts: 40 | Thanks. I'll repost in the shop section. I'm trying to figure out how to get the pics on a server...
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Welcome to the Stovebolt. See you around the garage forums. | | | | | Joined: Dec 2002 Posts: 3,447 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,447 | Welcome to the 'bolt. You can find the instruction on posting pix in the left hand column.
