5 members (jmoore, Woodcmiami, Ludwig.van.dille, Shaffer's1950, 1 invisible), 87 guests, and 1 robot.
Topics128,077
Posts1,056,280
Members48,441
#1333142 11/09/2019 10:12 PM
1950 suburban 3100 stock.
I am trying to replace my bearings and grease seal on my factory rear end. The bearings are pressed in and I cannot figure out how to knock them out. Is there a special tool needed for removal?
1950 SUBURBAN / SCHOOL BUS A.K.A "THE SCHOOL RUST"
H Online: Content
Yes, there is a special puller for those bearings, but you can usually use a "slide hammer" puller that's available to rent or borrow with a security deposit at some local parts stores. The one you'll need will have 3 internal-expanding jaws that grip the bearing outer race from the inside. I changed a similar set of bearings on my Dodge pickup a few weeks ago by cutting a slot through the outer bearing race with a die grinder after prying the bearing rollers out.
A welder will work fine. Run a small bead on inside of race ,as it cools it will shrink and come out. Die grinder will also work just fine .
!956 Gmc Napco 4x4 Factory line built .
That's great info! Thank you!
Follow up question.....
The grease seal has a rubber lip on one side. Does the rubber lip go inside towards bearing or outside towards wheel?
AD Addict & Tinkerer
Grease seal lips usually always face the fluid that it is trying to stop. The reason is any internal pressure will put additional pressure on the seal. If it was installed the other direction, any pressure would push the lip seal open allowing more fluid to escape.
Face it toward the bearing.
Phil
Project Journals
Stovebolt Gallery Forum
H Online: Content
Face the garter spring that tightens the seal lip against the shaft toward the fluid you want to seal.
Sack has the answer above. Weld a nice bead around the race. That will shrink it and make it a lot easier to get out. Most of the time it slides out.
