6 members (Greg '46, Hotrod Lincoln, Phak1, Otto Skorzeny, 2 invisible), 234 guests, and 2 robots.
Topics128,080
Posts1,056,063
Members48,433
#1332261 11/02/2019 11:17 AM
Hello, anyone had any experience with the differential carrier bearings that the Filling Station sells, looks like they might come from Korea by the picture on the website.
First choice I would scour ebay with a GM part number, that is how I found mine and got oem first over anything imported.Ended up being a little cheaper too, bonus!
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
Would you happen to know the GM part number or have access to it somehow?
What year and model truck?
46-54 1/2 ton are Hyatt 11445z, GM# 187434, 7450438, Hyatt KA-11445-Z, Timken 17887, 17831
https://www.ebay.com/itm/NEW-DEPARTURE-HYATT-11445Z-JOURNAL-ROLLER-BEARING/272618463996?epid=1801807781&hash=item3f7953a2fc:g:gvQAAOSw~CFY5AcM
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
If you pull it out and measure things it's usually straightforward to find something in a modern bearing catalog...
I swear by koyo bearings (japanese brand). Their part numbers are typically the same as timken or skf. Also good.
koyo bearing catalog
more special purpose bearings
'59 Chevy Suburban, NAPCO
This is a 1954 1/2 t PU
Thanks for the responses
Check with NAPA also, their top grade of bearings are really good. It helps to have a bearing number before going in.
