8 members (68ironhead, GMCJammer51, Bill Hanlon, Gdads51, TrknGMC, 53 green 1- ton, msmall, 1 invisible),
181
Mod | | | Forums66 Topics128,086 Posts1,056,094 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | Hello, anyone had any experience with the differential carrier bearings that the Filling Station sells, looks like they might come from Korea by the picture on the website.
| | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | First choice I would scour ebay with a GM part number, that is how I found mine and got oem first over anything imported.Ended up being a little cheaper too, bonus!
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | Would you happen to know the GM part number or have access to it somehow? | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | What year and model truck? 46-54 1/2 ton are Hyatt 11445z, GM# 187434, 7450438, Hyatt KA-11445-Z, Timken 17887, 17831
https://www.ebay.com/itm/NEW-DEPARTURE-HYATT-11445Z-JOURNAL-ROLLER-BEARING/272618463996?epid=1801807781&hash=item3f7953a2fc:g:gvQAAOSw~CFY5AcM
| | | | | Joined: Aug 2019 Posts: 242 'Bolter | | 'Bolter Joined: Aug 2019 Posts: 242 | If you pull it out and measure things it's usually straightforward to find something in a modern bearing catalog... I swear by koyo bearings (japanese brand). Their part numbers are typically the same as timken or skf. Also good. koyo bearing catalogmore special purpose bearings
'59 Chevy Suburban, NAPCO
| | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | | | | | | Joined: Jun 2017 Posts: 120 'Bolter | | 'Bolter Joined: Jun 2017 Posts: 120 | | | | | | Joined: Feb 2000 Posts: 5,215 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,215 | Check with NAPA also, their top grade of bearings are really good. It helps to have a bearing number before going in. | | |
