2 members (tclederman, Peggy M),
84
Mod | | | Forums66 Topics128,175 Posts1,057,052 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | I need to raise my driver's side door about 1/4". It's gouging the strike plate and sometimes doesn't latch.
I loosened the 3 bolts on the pillar ends of each of the hinges. The door won't slide up (or down). I have put a floor jack under the door to gently coax it upward, but it won't budge.
Has corrosion I can't see locked it into place.
Thanks!!!!
1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Mar 2010 Posts: 10,301 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,301 | How far off is the beltline at the front of the door and the cab?
| | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | 52,
I hate to say this but what's the beltline?
| | | | | Joined: Mar 2010 Posts: 10,301 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,301 | It is the ~1 1/4" bulge which surrounds the cab at the level of the of the wipers. It is where the original pinstripe is located. It is a great reference for aligning doors to cab.
| | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | Ah yes. The beltline at the front of the door is about 1/4" (7/32" actually) lower than that on the cab. After lossening the 6 hinge bolts, the door still won't move up or down. Beltline. . 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Oct 2005 Posts: 4,260 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,260 | Remove a bolt at the A pillar on the upper and lower hinge. See which one is out of hole, remove hinge, elongate hole, reinstall hinge, restart adjustment procedure. Repeat as necessary. | | | | | Joined: Mar 2010 Posts: 10,301 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,301 | Lets back up a few steps before we proceed further. Did you rebuild the hinges? If not, there is a good chance that worn hinge pins are causing door sag which cannot be compensated for at the hinge pillar. Worn hinge pins are the #1 cause of beat up door latches and poorly fitted doors. Carl
| | | | | Joined: Oct 2005 Posts: 4,260 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,260 | | | | | | Joined: Mar 2010 Posts: 10,301 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,301 | I may not be able to weld a panel without warping it beyond repair, but I can mount a door.  (Your high level of metal work inspires me to do mechanical work.) Carl
| | | | | Joined: May 2001 Posts: 1,907 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,907 | Thanks, Guys,
I'm slow at fixing things (and replying!). Would worn hinge pins cause the hinge to not slide up or down when the 6 pillar bolts are loosened? Seems the hinge should still slide but maybe not enough to compensate for a worn hinge pin.
Thanks again!!
| | | | | Joined: Mar 2010 Posts: 10,301 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,301 | Is there any evidence that the hinge pillar has been repaired? I had the same issue you are having after replacing the lower hinge pillar which has the lower hinge pocket within it. I measured wrong when I cut the old one off and welded the new one in which would not allow movement of the door up or down.
| | | | | Joined: Jun 2018 Posts: 14 'Bolter | | 'Bolter Joined: Jun 2018 Posts: 14 | HInge has 4 bolts, one is deeply recessed. Have you checked, that this bolt is also loosend
1947 3100 Delux
| | | | | Joined: Mar 2010 Posts: 10,301 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,301 | HInge has 4 bolts, one is deeply recessed. Have you checked, that this bolt is also loosend I am aware of the captive nut in that recess, but could never understand why I have never seen a bolt in there.
