3 members (Rusted Nut, 1955 1 Series, Wally / Montana), 301 guests, and 2 robots.
Topics128,152
Posts1,057,011
Members48,460
W Online: Content
I need to raise my driver's side door about 1/4". It's gouging the strike plate and sometimes doesn't latch.
I loosened the 3 bolts on the pillar ends of each of the hinges. The door won't slide up (or down). I have put a floor jack under the door to gently coax it upward, but it won't budge.
Has corrosion I can't see locked it into place.
Thanks!!!!
How far off is the beltline at the front of the door and the cab?
W Online: Content
52,
I hate to say this but what's the beltline?
It is the ~1 1/4" bulge which surrounds the cab at the level of the of the wipers. It is where the original pinstripe is located. It is a great reference for aligning doors to cab.
W Online: Content
Ah yes. The beltline at the front of the door is about 1/4" (7/32" actually) lower than that on the cab. After lossening the 6 hinge bolts, the door still won't move up or down.
Beltline
Remove a bolt at the A pillar on the upper and lower hinge. See which one is out of hole, remove hinge, elongate hole, reinstall hinge, restart adjustment procedure. Repeat as necessary.
Lets back up a few steps before we proceed further.
Did you rebuild the hinges? If not, there is a good chance that worn hinge pins are causing door sag which cannot be compensated for at the hinge pillar.
Worn hinge pins are the #1 cause of beat up door latches and poorly fitted doors.
Carl
He's right, you know.
I may not be able to weld a panel without warping it beyond repair, but I can mount a door. smile
(Your high level of metal work inspires me to do mechanical work.)
Carl
W Online: Content
Thanks, Guys,
I'm slow at fixing things (and replying!). Would worn hinge pins cause the hinge to not slide up or down when the 6 pillar bolts are loosened? Seems the hinge should still slide but maybe not enough to compensate for a worn hinge pin.
Thanks again!!
Is there any evidence that the hinge pillar has been repaired? I had the same issue you are having after replacing the lower hinge pillar which has the lower hinge pocket within it. I measured wrong when I cut the old one off and welded the new one in which would not allow movement of the door up or down.
HInge has 4 bolts, one is deeply recessed. Have you checked, that this bolt is also loosend
1947 3100 Delux
I am aware of the captive nut in that recess, but could never understand why I have never seen a bolt in there.
