| | | Forums66 Topics128,150 Posts1,056,985 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | Hey All,
I have the truck up on the lift and I am thinking I want to replace the entire brake line system from hub to hub. Has anyone here done that in the last few years? The truck is a 1951 That I pulled out of a preachers field. I have brought the motor back to life, reconditioning as I go. Now that It's up on the lift and I redid the braking in all four wheels I want to keep it going. I see several "Kits" out there but I am sure some are better than others and probably include more than others. So tell me what you guys know, Who has done a HUB to HUB line replacement, where did you get your kit and what did you like or dislike about it.
Thanks!
Walter
*UNDER CONSTRUCTION* 1953 Chevrolet 3100 1/2 ton-previously abandoned resto. My Project BoltI hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
| | | | | Joined: Jan 2019 Posts: 14 'Bolter | | 'Bolter Joined: Jan 2019 Posts: 14 | Did it on my 58 Apache 32 about 1 year ago. Got all the metal lines in stainless from Inline tube, not that much more than plain steel. Got the shoes off the shelf @ NAPA. I don't remember where the wheel cylinders and rubber hoses came from. Stock master cylinder I'm pretty sure was Classic Parts.com. Every thing went smooth. I love pre-bent lines. I've used Inline tube on 2 60's cars as well. | | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Buy a 25' roll of Copper-Nickel Brake line from your local parts store and make your own. You'll need to borrow or buy a Double Flare Tool and Tubing Bender. Then take one line off at a time and bend a new to match, it really is easy to do. When you tighten the fittings up tight, then back it off and re-tighten it again, this helps seat the flares together. Good luck! Mike B  | | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | Where would I get the appropriate fittings?
| | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | Either re-use the old ones if good or take then to the parts store to match up and buy new...any NAPA or good parts store should have everything you need to do this job. Mike B  | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | I replaced every part in my brake system except the backing plates. I purchased pre-bent stainless steel lines from In-Line tube https://www.inlinetube.com/ . I was able to find all the brass fittings at NAPA. I was quite happy with the brake lines with the exception of my choice of selecting stainless steel lines. I had some leaking issues at the fittings. That required repeatedly tightening and loosing the fittings several times. Apparently the flare angle is slightly different on the stainless fittings. It has been in service 6 years now and no leaks after the initial install. The lines still look like new. I am happy with them but would probably not go with stainless if I did this again. You can find a lot of info about brake line choices searching this forum. | | | | | Joined: Jul 2007 Posts: 444 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 444 | Walter , Inline Tube makes a Stainless Steel ready made kit with fittings pre installed . LINK for your 1953 half ton https://www.inlinetube.com/products/sctb5301Scroll down & take a look at related products . George '54 3600
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I have bought pre-bent stainless steel lines from Inline Tube and Classic Tube - they even matched-up the correct lengths and ends needed on a 54 3104 Hydra-Matic system. A few lines were a little long, but that was not a big problem (being too short would have been problem). | | | | | Joined: Dec 2017 Posts: 1,652 'Bolter | | 'Bolter Joined: Dec 2017 Posts: 1,652 | I used stainless lines from inline tube also. I will admit I would not use the stainless again. Those lines hemorrhaged every where and It took me forever to get the lines to seat correctly and stop leaking. What a mess. I recently did the lines on a friends 57 chevrolet (car) and used regular prebent steel lines from inline tube. Not a single leak.
Mike
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I had no breakage in three different stainless steel systems. I had/have no leakage in three different stainless steel systems(5-15 years old Just lucky, I guess? However: do not be afraid to use A LITTLE "stainless steel grease" on the tube ends (nut side of tube). Stainless Steel Anti-Seize Lubricant
Slowly/lighty/gently tighten and untighten the attachment "nut". Use a little tighter last tightening of each attachment nut. | | | | | Joined: Mar 2007 Posts: 3,444 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,444 | Steel brake line use a 45 dergee flare fitting while Stainless use a 37 degree flare fitting. You will need to seat the fitting repeatedly as Tim stated to get the flare to seat evenly. Once It's seated there should be no issue with leaks.
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | 1. Don't buy tubing and flare your own. 2. Buy preflared sections at FLAPS or a regular steel kit.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I talked with the people at the company I used for SS on my 1954 3104 Hydra-Matic truck. They said they would use original-style fittings (I sent them my fitting for them to compare).
I'll see if I can find the name of the company. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | SS is fine although hard to work. Most shops around here have CuNi in various lengths, very handy.
Ed
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If you will/can make the brake lines yourself, I agree with Ed.
If you are having a shop do it for you: get an estimate and compare it to stainless steel lines from a vendor (there are two or three good vendors that sell/make stainless steel brake lines for our old trucks). | | | | | Joined: Mar 2010 Posts: 10,303 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,303 | I like the SS inline brakeline kits. They fit, You will never need to replace them or worry about them. SS flares are harder to seat in the fittings, but tightening and loosening 3-4 times while watching where the wrench stops each time makes it very doable. You will know when you are done when the wrench won't go further than where the previous tightening sequence ended up. Carl
