6 members (55shaker, Wickedbass, FAST55, rfs56trk, Hotrod Lincoln, Hanks custodian), 57 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
#1330366 10/18/2019 6:36 PM
Looking for suggestions as to what some of the rest of you might use to protect the painted step area inside the driver and passenger doors on a 1958 Apache.
Pictures are extremely helpful.
Thanks in advance.
I suppose one could lay down non-skid if it really was an issue. I have a '59 and never gave it a second thought. But then again I own a shop truck. Don't believe they rolled off the line with it.
Bedliner. Either the spray can stuff or the actual 2-component commercial stuff (Rhinoliner, and the like).
There are stick-on strips available which can be put on the high ribs. They are sandtex in nature and look nice when installed. I don't know where you can find these strips. I have seen them on one of our member's big truck.
Carl's suggestion is a good one as well. I have a roll of sticky anti-slip that I have used for to top of my boat trailer tongue, etc. That would work for your step area. I just looked at it, thinking it was a 3M product, but there's no marking on it. I have no idea where I got it, it's been so long ago.
I'm with Carl on this one.....I got a sheet of the stuff at Lowe's for cheap and cut strips off of it and put them the ribs of the exterior running boards and they have lasted very good....and if I need to replace one, no sweat, they stick on.
I like this:
1951 Chevy Panel Truck
I like the carpet idea for a nice interior. I use velcro to hold mine in place.
Mark
i think the material Carl is referring to is stick on vinyl gravel guard found on ebay. another option is 3m 84906 paint protection film, this is clear and good option where your toe may kick the paint. it comes in 6" x 84" roll. MikeB uses a material for new floor protection found at floor shops, and just frequently replaces it. Pat
