Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
9 members (51sub, farmallb, 1955 1 Series, walter74, TexasA&M48Truck, baldeagle, dt235sd, Charles in CA, 32Fordpuchoptop), 30 guests, and 2 robots.
Topics128,005
Posts1,055,256
Members48,418
#1330807 10/22/2019 9:28 PM
Does anyone know where I can but Coupling ( torus ) gasket for a 18 bolt ( small torus cover ) ? all I seem to find are the 30 bolt hole 14" ones
I’ll bite. Other than a three dimensional geometry ‘donut’ (I looked it up), what is a ‘torus’ and where does it go on a truck?
FATSCO Transmission Parts
www.fatsco.net
beltfed #1330814 10/22/2019 10:55 PM
Hydra-Matic transmission torus readings
What, in general, is a torus?
Here is a video.
I believe Chevrolet used a big square O ring and GMC actually used a gasket. Does your flywheel and torrus cover have a groove cut for the O ring?
beltfed #1330838 10/23/2019 1:10 AM
The predecessor to a torque converter in and automatic transmission essentially.
It's that flat gasket surface and most suppliers only have the O ring type . And mine is the 20 hole note 30 only made for about a year and a half . was hoping someone had actually bought one that had same problem as me .
Has anyone else done the 18 bolt and found a gasket somewhere ?
All I can find is the o ring type but mine flat gasket .
