2 members (MickeyP, KingG),
60
0
Mod | | | Forums66 Topics128,007 Posts1,055,281 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2019 Posts: 17 New Guy | | New Guy Joined: Aug 2019 Posts: 17 | Does anyone know where I can but Coupling ( torus ) gasket for a 18 bolt ( small torus cover ) ? all I seem to find are the 30 bolt hole 14" ones | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I’ll bite. Other than a three dimensional geometry ‘donut’ (I looked it up), what is a ‘torus’ and where does it go on a truck?
| | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | FATSCO Transmission Parts www.fatsco.netJerry
| | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | I believe Chevrolet used a big square O ring and GMC actually used a gasket. Does your flywheel and torrus cover have a groove cut for the O ring? | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | I’ll bite. Other than a three dimensional geometry ‘donut’ (I looked it up), what is a ‘torus’ and where does it go on a truck? The predecessor to a torque converter in and automatic transmission essentially. | | | | | Joined: Aug 2019 Posts: 17 New Guy | | New Guy Joined: Aug 2019 Posts: 17 | It's that flat gasket surface and most suppliers only have the O ring type . And mine is the 20 hole note 30 only made for about a year and a half . was hoping someone had actually bought one that had same problem as me . | | | | | Joined: Aug 2019 Posts: 17 New Guy | | New Guy Joined: Aug 2019 Posts: 17 | Has anyone else done the 18 bolt and found a gasket somewhere ? | | | | | Joined: Aug 2019 Posts: 17 New Guy | | New Guy Joined: Aug 2019 Posts: 17 | All I can find is the o ring type but mine flat gasket . | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | | | |
