5 members (rick46ia, elhippie64, Peggy M, JW51, 1955firstseries), 66 guests, and 2 robots.
Topics128,022
Posts1,055,361
Members48,420
#1330676 10/21/2019 5:41 PM
I have my 1962 c-30 I am rebuilding the front suspension. I can get everything I need for it through many sources except the front lower control arm bushings and shaft. Either they never wear out or absolutely nothing was ever made for them. Does anybody know any place I can get these parts of even adapt something new. If not I might have to junk this truck do to safety concerns about the front end. Any help much appreciated. David
1957. GMC F350
junk it.. Im sure I can do something with it
Unconventional Thinker
Can the cross member that bolts to the frame, including the control arms, be replaced by one from a newer model? Or is '62 a torsion bar suspension on the C30?
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
It appears you can swap out the cross member and associated suspension components and then you'd have front disc brakes. I don't want to get into trouble by posting links to other forums, but I just did a search on google for "1962 c30 front suspension" and got a few hits, some are from the 67-72chevytruck forum.
Shane
Shane's Toys...
It is a torsion bar suspension.. I am not fimiliar enough with them to know what can interchange. Thanks I will do the search🤪
1957. GMC F350
I have a 1960 c10. It is a torsion bar suspension. I just replaced it with a 1973 to 87 front suspension. I unbolted the engine cradle, torsion bars and a-arms. The "new" engine cradle with the 73-87 all in one piece. It bolted right up. There are a couple of holes that needed to be drilled because they are in a different location on the newer front end. It was easier than I thought. Now I have coil springs and disk brakes.
EDIT: The C30 frame is the same, so you could do this mod to your frame.
