1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2018 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 32 | Ive got a 1947 Advanced design GMC 300
Are brake parts even still available for big trucks like this? I haven't taken the drum off to inspect but I can only assume the pads need replaced. The truck has been sitting since the 70's. If they are savable thats great but just in case does anyone have leads on parts for these bigger trucks?
its frustrating that all the 1/2 and 3/4 ton trucks have brand new parts available but were left out to dry.
Logan 2010 Silverado 2500HD 1947 GMC 300
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 47GinPole, don't panic, if we can't help you find shoes and lining off the shelf I'm sure there is someone maybe even close to you that can reline your original shoes if the mounting flanges that the lining bolts to are in good shape. In any case carry on and do your braking system inspection and give us a list of the parts you want/need to bring it back into correct operation, hope that helps. | | | | | Joined: Apr 2007 Posts: 1,038 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 1,038 | Don't know where in AZ you are but Phoenix Brake and Clutch will be able to help you. It is located on I-17 near the McDowell exit west of downtown PHX. They can reline your shoes and be sure to ask for the softest lining (they will grab and stop the best). Also, they can reline your cylinders if they are pitted (I think they ship them out somewhere). Hoses and rebuild kits they will have.
Also, when they reline your shoes, take your drums in, so they can arc the shoes to the individual drums.
Brake lines you will have to do yourself.
Kent | | | | | Joined: Jun 2018 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2018 Posts: 32 | Ill have to check out phoenix brake and clutch. I go to phoenix on a pretty regular basis so that could work out just fine. Thanks for the responses!
