7 members (Gdads51, joe apple, 78buckshot, Hanks custodian, Otto Skorzeny, 1955 1 Series, Rexville48),
122
Mod | | | Forums66 Topics128,070 Posts1,055,896 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | Hello, I am looking at a '65 Chevy C10 and trying to learn about it. I am new to both old trucks and this site. My question is: The original engine has been replaced with a 250 in the truck I am looking at. How can I determine what the original engine was? I would like to know if it was a 230 or 292. I do not think it was a V8 283.
Thank you for any info.
Kevin 1965 Chevy C10 Longbed Fleetside
| | | | | Joined: Nov 2014 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 70 | The engine mounts where offset on a 292 if it ever had a 292 in it there would be evidence of the perch being bolted in the forward set of holes. The data plate on the left kick panel could have the engine info on it, earlier years did but not sure when they stopped it, They left the factory with a sticker on the inside of the glovebox door that listed all the options if it had an optional engine in it then it would be specified on the sticker.
ESum
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Welcome to the Stovebolt  The 230 was standard issue in the 1965 C10 with the 292 or 283 being options. Mike B  | | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | As per Mike’s & Joe’s posts.More specifications than you need/want to know about 1965 Chevrolet Trucks? | | | | | Joined: Oct 2019 Posts: 449 'Bolter | | 'Bolter Joined: Oct 2019 Posts: 449 | A lot of good information. I appreciate it very much guys!
| | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | Some GM shop manuals list the VIN information in the front of them along with some parts manuals. | | |
