1 members (Hotrod Lincoln),
104
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | Its been awhile but am back on the doors on my 59; need to remove the window assy . There are 4 clutch drive screws I have a 1/4 to small and a 5/16 to big driver. They of Corse are rusted. any ideas on removal? vice grips may fit on the two for the crank but the other two are in a recessed area. can i grind a old phillips in to a clutch head? | | | | | Joined: Feb 2017 Posts: 83 Vintage Truck & Tractor | | Vintage Truck & Tractor Joined: Feb 2017 Posts: 83 | I trimmed up the driver. I bought it at napa and it was like a half size in between. Like.you, it was too big. I had a clutch head fitting for an impact gun and that breaks em loose. Pretty much anything you can get in the slot will work once I ended up replacing the clutch head with pan head bolts from fastenal
Current project; 1961 C20, 235 I6
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Sometimes a flat blade screwdriver will fit tight enough to turn one out.........on occasions I have took a small cut off disc and cut a horizontal slot in them and twisted them out....and remember, always try to "tighten" them first. Sometimes that will help brake them loose. Of course if you find a clutch head bit to fit an impact wrench as David said above, a good whack will do wonders....including twisting them off. If that happens, just drill them out. If all else fails, grind the head off then twist them out. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Spray the head of the screw with a solvent of your choice, then use a dental pick to thoroughly dig out any debris in the clutch head area. I don't know how the different sizes are numbered, but I do know that someone makes a clutch head bit that will fit your window assy screws. Carl
| | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | Well I tried the visegrips and two bolts came loose, made a bitt that would fit in the other two and started to strip the holes. thinking if a quick weld of the tool to bolt and seeing if that works. Mosquitoes say its time to go in for the night.
| | | | | Joined: May 2015 Posts: 11,054 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,054 | Heat is your friend when getting rusty screws out. Heat them till they glow cherry red, then try again. Alternate heat and penetrating oil for the really tough ones.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Well I tried the visegrips and two bolts came loose, made a bitt that would fit in the other two and started to strip the holes. thinking if a quick weld of the tool to bolt and seeing if that works. Mosquitoes say its time to go in for the night. After you weld your tool to the head, it will nearly fall out. A welder applies the perfect amount of heat in a very specific spot, and the screw comes right out.
| | | | | Joined: Jul 2014 Posts: 1,289 Moderator for Tons o' Fun , Co-Moderator Driveline Forum | | Moderator for Tons o' Fun , Co-Moderator Driveline Forum Joined: Jul 2014 Posts: 1,289 | Not to hijack the conversation but I found there's a huge difference in the quality of clutch head bits. I recently purchased some used Proto clutch head bit sockets and they fit the clutch head bolts very well, nice, snug, solid fit.
Ron - - Dusty53 1954 Chevy 3604In the Gallery Forum "You can't dance with the Devil and then wonder why you're still in Hell." "They will forget what you've said, and they will forget what you have done but they will never forget the way you made them feel." | | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | Well I tried the bit again and it ate the head out. so I drilled the las t 2 and removed the part from the door. it was rusted badly so will drilland tap it. good news the rest of the door window removel went well... off to sand blast mon am. Thanks for the support
