2 members (sron48, Jay R),
96
Mod | | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 29 Junior Member | | Junior Member Joined: May 2005 Posts: 29 | A buddy of mine wants to use a muncie 465 4 speed tranny in his hot rod pick-up. He also wants to run this on Saturday nights. I told him he may have a hard time with it, since it is a top load shifter. What do you guys think ?
Jase | | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | Your right it ain't going to shift quick, at least that's my experience. I have a 68 C20 with a 465. The standard lever for the 465 is quite long, cutting it down would help. I replaced the original lever in my 68 with 435 lever out of a 69 GMC, had to tweak it a bit to clear the bottom of the dash. I also polished the part of the lever that drops into the shifting forks, didn't help a whole lot. If some one has some tricks I would sure like to hear them. Larry
I don't own a vehicle that isn't old enough to drink. | | | | | Joined: May 2005 Posts: 29 Junior Member | | Junior Member Joined: May 2005 Posts: 29 | Thats what I thought. I told him that. Its a truck transmission. A lot of "slop" or travel in the shift pattern. Thanks for the second opionion.
Jase | | | | | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | Let him use it he will find out soon enuff the main problem I have found with them besides slow shifting is if you realy push them hard (drag racing ) thay will jam between 2nd and 3rd
also the wide ratio will slow him down a bit but would depend on what egine he was running and how much power it was putting out | | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I agree with that. For racing, a close ratio Muncie would be great for banging the gears. I'd keep the truck transmission for truck duties, hard to beat that super granny gear for a truck. Rock crawlers love it.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Jul 2005 Posts: 8 Junior Member | | Junior Member Joined: Jul 2005 Posts: 8 | I put one of these into a rock climbing jeep about 6 yrs. ago. Man, it was indestructable, but a racing transmission, absolutely not. It was a truck tranny, and man, it was like shifting a 50 year old uhaul van. It was a bear that would not always find 3rd if you were in a hurry, not fun for cruising at all.
I agree with the others, tell him to switch to a close ration muncie, or go with something crate based from summit. Otherwise the slop he will feel on the street alone will make him think he bought a piece of junk. | | | | | Joined: Jun 2005 Posts: 221 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 221 | if he can speed shift a granny gear 4 spd with or with out the clutch(takes lots of practice)hes a better truck driver than i am and i been doin it for 25 years. | | | | | Joined: May 2005 Posts: 29 Junior Member | | Junior Member Joined: May 2005 Posts: 29 | Thanks or the input. Thats what I told him. He's looking at a saginaw side loader 2-ring transmission. Thanks guys.
Jase | | | | | Joined: Aug 2004 Posts: 90 Member | | Member Joined: Aug 2004 Posts: 90 | i have a spare 465 (w/86k miles) if he needs it. i sure don't anymore jim
Gooday Jim
small wheel moves by fire and rod, big wheel fires by the grace of god, everytime that wheel turns round, bound to cover just a little more ground.
