8 members (Chip O, MNSmith, Woodcmiami, LAROKE, Hotrod Lincoln, Southerntruck, gswbbc, 1 invisible), 113 guests, and 3 robots.
Topics128,032
Posts1,055,523
Members48,425
#132621 06/24/2005 1:08 AM
Junior Member
Junior Member
A buddy of mine wants to use a muncie 465 4 speed tranny in his hot rod pick-up. He also wants to run this on Saturday nights. I told him he may have a hard time with it, since it is a top load shifter. What do you guys think ?
Jase
#132622 06/24/2005 6:49 AM
Your right it ain't going to shift quick, at least that's my experience. I have a 68 C20 with a 465. The standard lever for the 465 is quite long, cutting it down would help. I replaced the original lever in my 68 with 435 lever out of a 69 GMC, had to tweak it a bit to clear the bottom of the dash. I also polished the part of the lever that drops into the shifting forks, didn't help a whole lot. If some one has some tricks I would sure like to hear them.
Larry
I don't own a vehicle that isn't old enough to drink.
#132623 06/24/2005 12:15 PM
Junior Member
Junior Member
Thats what I thought. I told him that. Its a truck transmission. A lot of "slop" or travel in the shift pattern. Thanks for the second opionion.
Jase
#132624 06/24/2005 10:37 PM
Let him use it he will find out soon enuff
the main problem I have found with them besides slow shifting is if you realy push them hard
(drag racing ) thay will jam between 2nd and 3rd
also the wide ratio will slow him down a bit but would depend on what egine he was running and how much power it was putting out
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
#132625 06/29/2005 5:01 AM
I agree with that. For racing, a close ratio Muncie would be great for banging the gears. I'd keep the truck transmission for truck duties, hard to beat that super granny gear for a truck. Rock crawlers love it.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
#132626 07/06/2005 3:27 PM
Junior Member
Junior Member
I put one of these into a rock climbing jeep about 6 yrs. ago. Man, it was indestructable, but a racing transmission, absolutely not. It was a truck tranny, and man, it was like shifting a 50 year old uhaul van. It was a bear that would not always find 3rd if you were in a hurry, not fun for cruising at all.
I agree with the others, tell him to switch to a close ration muncie, or go with something crate based from summit. Otherwise the slop he will feel on the street alone will make him think he bought a piece of junk.
#132627 07/07/2005 12:17 AM
V
V Offline
if he can speed shift a granny gear 4 spd with or with out the clutch(takes lots of practice)hes a better truck driver than i am and i been doin it for 25 years.
#132628 07/08/2005 1:49 PM
Junior Member
Junior Member
Thanks or the input. Thats what I told him. He's looking at a saginaw side loader 2-ring transmission. Thanks guys.
Jase
#132629 07/09/2005 8:58 PM
i have a spare 465 (w/86k miles) if he needs it. i sure don't anymore
jim
Gooday
Jim
small wheel moves by fire and rod,
big wheel fires by the grace of god,
everytime that wheel turns round,
bound to cover just a little more ground.
