| | | Forums66 Topics128,038 Posts1,055,585 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've been offered a 60's Ford van for hauling it away. I thought that if it has a 9-inch rear it might be worth the trouble.
I don't know how to be sure what I'm looking at. Can anyone tell me how to identify a 9-inch and tell it from whatever else might be under an old van?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Dec 2001 Posts: 58 Member | | Member Joined: Dec 2001 Posts: 58 | Early 60's, probably not late 60's, could be. The 9" is a removable carrier type rear, as is the 8". The two lowest nuts that hold the center section in can't be removed with a socket,on the 9 incher, you must use a box end wrench. On the 8 incher a socket will go straight on the nuts. They look alike so check before you haul it out. If it's an 8", leave it there | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Hey Joe that link is great!
I'm going to try to crawl under it tomorrow and see what it is... I guess I need it not to rain tomorrow!
Thanks Guys!
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | To Many to count.Im running a 64 9" in my 51 chevy pu.Have a lot of rearend play in the ring and pinion.One guy said if it don't make noise,it will be fine.Do ya know the clearance for the ring &pinion adj.My guess would be 3 to 5 thousand play. Is this correct????? thank you
dan-pa
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Well I finally got a look under the van, and its definately NOT a 9-inch. So I declined the opportunity to drag it home...
Thanks for the help!
