4 members (MickeyP, Ole49GMC, Tronman, Peggy M), 83 guests, and 1 robot.
Topics128,043
Posts1,055,610
#132552 06/12/2005 9:57 PM
I've been offered a 60's Ford van for hauling it away. I thought that if it has a 9-inch rear it might be worth the trouble.
I don't know how to be sure what I'm looking at. Can anyone tell me how to identify a 9-inch and tell it from whatever else might be under an old van?
#132553 06/13/2005 12:14 AM
Early 60's, probably not late 60's, could be. The 9" is a removable carrier type rear, as is the 8". The two lowest nuts that hold the center section in can't be removed with a socket,on the 9 incher, you must use a box end wrench. On the 8 incher a socket will go straight on the nuts. They look alike so check before you haul it out. If it's an 8", leave it there
#132555 06/13/2005 6:05 AM
Hey Joe that link is great!
I'm going to try to crawl under it tomorrow and see what it is... I guess I need it not to rain tomorrow!
Thanks Guys!
#132557 06/13/2005 4:14 PM
To Many to count.Im running a 64 9" in my 51 chevy pu.Have a lot of rearend play in the ring and pinion.One guy said if it don't make noise,it will be fine.Do ya know the clearance for the ring &pinion adj.My guess would be 3 to 5 thousand play. Is this correct????? thank you
dan-pa
#132558 06/18/2005 8:18 PM
Well I finally got a look under the van, and its definately NOT a 9-inch. So I declined the opportunity to drag it home...
Thanks for the help!
