0 members (),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 28 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 28 | So, I drove down to Iowa and picked up a really nice 235 to swap out in place of my tired 216 in my 1952 3600. The 235 is a 1954 model. I see two differences moving forward. It appears the pulleys are narrower than mine on the 216. I will be using the generator off of my 216 which has the wider pulley. Can the pulley on the generator be changed to the narrower pulley? What is my best plan of attack? Thanks JS
| | | | | Joined: Jan 2017 Posts: 308 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 308 | call Joe Mendola in AZ--520-235 2659--he has what you require-Bill | | | | | Joined: Aug 2017 Posts: 660 'Bolter | | 'Bolter Joined: Aug 2017 Posts: 660 | Yes, I did the same I also used most of my 216 parts. Make sure the harmonic balancer matches the belt size. 5/8" I believe.
1950 Chevy 3100
| | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | You can either swap the balancer and water pump from your 216 to the 235, which will solve the belt problem, or change the pulley on your generator to the one with the narrower belt groove. Just be sure all the pulleys match, whichever way you choose to go. I'd suggest using the wide belt components and adapting the center-bolt valve cover to fit the 235 to make the engine bay look closer to original. Jerry
