4 members (78buckshot, Wally / Montana, FishinToms53, klhansen), 57 guests, and 2 robots.
Topics128,053
Posts1,055,778
#1324428 09/02/2019 1:32 AM
Hello. I have just purchased a 1954 3600 3/4 ton and have lots of questions. I am searching the web and ordering a few books and manuals along the way. I used the VIN buster to determine I have a truck from Atlanta and it is a commercial truck. It has a 5 window cab and a some what of a home made flat bed on duals. First thing I needed to do was replace a broken front leaf spring, WOW, lots of learning already. My first big question is it has 8 lug hubs on the front. Is this something I can update to disc brakes? Seems the only kits I can find are for 5 and 6 lug (1/2 ton) trucks? Looking forward to working on this truck but already see how it can be overwhelming for sure.
Welcome to the 'bolt. This is not really the forum to ask too many questions though. Please use the specific forums for questions pertaining to that forum. Check the tech tips for that brake conversion... or ask about it in the Big Truck forum.... have fun and don't lose hope.
Another quality post.
Real Trucks Rattle
Welcome to Stovebolt. Hope the Storm doesn't ruin your week.
Lots of great folks here. Just post questions in the most appropiate forum and we'll do the rest.
See you around the garage.
Welcome to the Stovebolt madness. There is no cure! shake As others have said, please ask your questions in the appropriate garage forum.
Big Bolt Forum Moderator
welcome to the site! as stated above, poke around in the tech forums and then ask questions in the appropriate one. Driveline forum is a good place to start for your brake questions, the big bolt section is for 1 1/2 and bigger trucks so, that would not be applicable to your 3/4 ton.
Mike
69Cuda #1324541 09/02/2019 10:51 PM
ADH Offline
Welcome! As you can tell from my post count I haven't been very active here. However my project '51 3600 is finally starting to progress with a long way to go so I may be on here more often in the future. I tried to send you a PM but got this message "Stroehlman is over their Private Topic limit." and don't know exactly what that means since you're new here. Anyway, if you can PM me, please do. I'm outside Jacksonville so not an insurmountable distance from you.
ADH
It is possible that a new members cannot use PMs until after they have posted at least 5 different posts/topics?
ADH #1324571 09/03/2019 12:50 AM
ADH I'll see what I can do so we can get together. Would love to have someone else with a 3600 to talk to very much!
One or both, add an email to your profile. Then you can contact each other until Stroehlman gets enough posts to PM.
