8 members (Phak1, 68ironhead, Bill Hanlon, Peggy M, 3B, Oswald, elhippie64, 1 invisible),
145
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,834 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2019 Posts: 4 New Guy | | New Guy Joined: Aug 2019 Posts: 4 | Starting things off I’ve been wrenching on a 1959 Chevrolet 3100 for a little over 4 years now trying to get the ol’ girl affectionately named “the pit” back to a daily driver. For a little over a month now I’ve been on the home stretch trying to get her running... and after some missteps (small electrical fire) I’m at a stand still. What I’ve done so far is.
1. Replaced the cap, rotor, condenser, coil, points (gapped to .019), spark plugs (.035) & wires 2. Rebuilt the starter and replaced the ignition switch/ solenoid 3. Re-wired the ignition harness and replaced the resistor 4. Rebuilt the carburetor and fuel pump 5. Adjusted the valves
After all this and having a fresh charge on the battery I can get the engine to turn over but it won’t start. Every 5th or so attempt the engine might sputter a bit but won’t idle. What am I missing?
Pat 1959 Chevrolet 3100 Original 235 w/ 3 on the tree
| | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | If it's been setting, you may have a stuck ring. Have you checked the compression?
Have you turned the distributor one way or the other while cranking? Have you verified TDC, and that the distributor is pointing at the right plug at the right time?
Are the spark plugs firing? Are the plugs wet from NOT firing? Have you tried a 12 volt battery on the starter ( if 6 volt ) to spin the engine much faster?
| | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | "Engine starting 101"
Gasoline engines need the following to run - - - - -check everything; assume nothing. Compression Fuel Spark Timing
First of all, do a preliminary valve adjustment. Forget "specifications"- - -with each cylinder at top dead center on the compression stroke, gently adjust the rocker arms to zero clearance, back the adjuster off 1/4 turn, and lock the nut down. Repeat for all cylinders. You can get around to an accurate adjustment once the engine is warmed up. Now test the compression. An engine with at least 65-70 PSI compression on all cylinders will start and run. 90-100 is better, but not absolutely necessary.
Check the initial timing and the firing order. Turn the engine clockwise at the front until the exhaust valve on #6 cylinder is fully open- - - -the last valve in line back by the firewall has the spring fully compressed. Keep rotating the crankshaft until that valve spring relaxes and the next one in line (intake) barely begins to move. NOW- - - -THIS IS IMPORTANT- - - -use the distributor cap tower the rotor is pointing toward as your #1 cylinder- - - -NOT #6. Follow the firing order around clockwise with the rest of the plug wires for an order of 1-5-3-6-2-4.
Set the static timing. With #6 cylinder at TDC and the firing order arranged as above, turn the distributor housing clockwise until the points close. Now turn the housing CCW until the points barely open. Lock the distributor housing down and reinstall the cap.
Check for spark: remove the coil wire from the center of the distributor cap, turn the ignition switch on, and crank the engine with the end of the wire held about 1/4" from the cylinder head or the block. You should get a strong, rapid spark. Reconnect the coil wire. Pull the #1 spark plug wire off the plug and use a spare plug grounded against the head to check for fire at the plug. Insulated pliers for these two tests are recommended unless you get your jollies by getting zapped by 10,000 volts or so.
Pour an ounce or two of gas down the carburetor, or make sure the accelerator pump has a good squirt, and crank the engine up. it WILL start if all the above is correct.
Most of the boneheaded blunders I do (yes it still happens after 60-sonething years of tinkering with engines) are because I ASSUMED something was right instead of checking it! Jerry _
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | When I am starting an engine for the first time, I find small incremental changes in the timing help me to get it going. That is what I suggest.
My second suggestion for the future is this. If you don't do this kind of work very often, next time try doing only one thing at a time. | | | | | Joined: Jan 2013 Posts: 1,518 'Bolter | | 'Bolter Joined: Jan 2013 Posts: 1,518 | To add, with the flywheel on the timing mark, or harmonic balancer on the set static (initial)timing mark, rotor positioned on number, and distributor turned to allow THE POINTS to be just barely OPEN. This is the sweet spot for starting your engine for the first time.
1953 Chevrolet 3100261 cu inch, sm420, 3.55 rear, torque tube still,omaha orange, still 6 volt, RPO green glass, side carrier spare, all done In the DITY GalleryVideo of the 261 running1964 GMC 1000305 Big Block V6, sm420, the next cab off restoration
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | Some are not aware there is a timing mark. It is in a hole in the flywheel. I marked the little bump with chalk to make stand out.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Aug 2019 Posts: 4 New Guy | | New Guy Joined: Aug 2019 Posts: 4 | Thanks for all the advice gents, I’ll report back with an update.
| | | | | Joined: Aug 2019 Posts: 4 New Guy | | New Guy Joined: Aug 2019 Posts: 4 | Alright... compression isn’t that good 90/90/90/60/0/40. Guess I’m in for a rebuild now. Thanks for all your help, I didn’t even think to do a compression test.
| | | | | Joined: Feb 2004 Posts: 29,850 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,850 | Do a "wet" test with a couple of ounces of oil in each cylinder. If the compression comes up you've got piston ring problems. If it doesn't you might get by with a valve job. Low compression on side by side cylinders can be from a leaky head gasket. The zero pressure cylinder sounds like there's a badly burned or stuck valve.
| | | | | Joined: Apr 2017 Posts: 87 'Bolter | | 'Bolter Joined: Apr 2017 Posts: 87 | Engine Starting 101 - for me that is a keeper, thanks for posting | | | | | Joined: Aug 2019 Posts: 4 New Guy | | New Guy Joined: Aug 2019 Posts: 4 | General update for you, pulled the head and removed the valves. Exhaust valves on cylinder 4/5&6 all had a lot of carbon build up and pitting on the mating surfaces. Valves look like the surface of the moon. Spent the weekend cleaning everything up and going to get them resurfaced this week. Hopefully next weekend the ol girl runs.
