1 members (Otto Skorzeny), 127 guests, and 4 robots.
Topics128,089
Posts1,056,442
Members48,443
#1322174 08/17/2019 2:43 AM
Jim C. Blue
Jim C. Blue
I got it moving under its own power today, grin but there is more to do.
-The brakes need bled. Took fluid and didn't see any leaks. Felt some pressure, but not enough.
There is also the matter of the rear right brake. The line to it was disconnected and sealed. frown
-Check the spark plugs since the wires needed replaced due to corrosion. There is also the choke to check as the pull knob feels stiff. It's running a little fast and used a lot of fuel. I also need to replace the carb gasket.
-Clean out the fuel tank before I attempt to use it. It looked okay inside, only a little dirty. Nice thing about having it in the cab!
-I've got some better tires lined up for it. That would be a good time to also check the brakes.
-Muffler, it has a straight pipe!
-Lights. Many of the little ones are broken or missing. It has already been converted to 12 volts!
-Have yet to try the hoist.
-Fix up the box and make it better so I can use it.
-Painting and such.
-Clean the cab, cover the seat and figure out what I will do for a headliner.
-More little things, but those are the most important things.
Ah, the fun of having an old FARM TRUCK! cool
Alexander's Automotive Assortment
  • 1953 GMC 9700 3-ton**
  • 1978 Plymouth Arrow
  • 1980 Jeep J10 Cargo Truck
  • 1985 Red Wagon Trailer (for cars)
  • 1986 Toyota Tercel Wagon 4wd
**(9700 in Canada or 450 in USA.)
It's always something, isn't it?
Glad you got her running. It's always a thrill when they fire up for the first time!
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Crusing in the Passing Lane
What size engine?
Ed
Jim C. Blue
Jim C. Blue
EdPruss: Claimed to be a 270, not original, but haven't checked the numbers yet.
SN starts with displacement, I. e. 270xxxx. Right side, stamped on machined pad, right side, aft of starter.
Ed
Jim C. Blue
Jim C. Blue
I forgot to take a photo of the door plaques. The engine will need cleaned before I get the ones off there.
What I really posting for:
What about brake parts for a three ton?
The post in here for brakes says only up to 2 tons, unless I missed something.
Is there a decently priced website that ships to Canada?
2 Offline
LMC truck will ship to Canada and guarantee landed price so no brokerage surprises
but they prob won't have 3 ton brake parts
Napa will surprise you, both in what they can get for your truck, and also with how expensive the parts will be smile
-s
Jim C. Blue
Jim C. Blue
Thank you!
As for EdPruss:
Model: 9783
Serial: 0978304655
Engine:G26319
Body Serial: 314
Must be really a Chevy engine since up north, eh?
Ed
Jim C. Blue
Jim C. Blue
Welp, that turned out to be a dud. Sure, the body, frame, engine, 12v conversion, etc. are good, but the box is ruined, hydraulic pump is toast and the real nail in the coffin: the back axle. Somehow, a previous user broke the drum and their 'fix' was to cut it off the hub. When I searched for replacement, no other truck had the same axle! Does this have some unique to the year axle or could it have been also replaced, like the engine did?
Either way, I'm no longer worried about it, has I got a similar '53 in much better condition that is mostly original. Should have it home soon and will post about it!
My wife just got me a Dana (think it's an S130) rearend for my '52 9700 GMC.
2003 ford F450. Simply unbolt hangers from the ford frame, it's the same width frame as the GMC. Mines not in yet, but looks to be a very simple swap, I'll end up with 4.88 gears, limited slip, and 19.5 rims with Radials. Just have to drill off my factory hangers off the frame, roll this under and bolt it up.
So, an easy option to go to (or, I also have possibly the same rear as you, that I'm not using) mine is an Eaton 2 speed.
1953 Chevrolet 1100
Grandpa's truck
Story in Big Bolts
1952 GMC 9700
Story in Big Bolts
1948 Chevy Pickup
"Two brothers; two trucks"
In the DITY Gallery
3B Offline
Hy Alex Arrow and guys, I must have been away in Oregon when this topic was first started. At any rate a little education on Canadian GMC and Chevrolet Maple Leaf trucks, Canadian engines on which the serial number begin with the letter "G" are 248s. GMC 9700 series and Chevrolet Maple Leaf 1700 series are more often than not powered by GMC 248 engines whose serial numbers begin with the letter "G". There was an option available back in the day to install a 270 engine in the GMC trucks 9700 series.
What is your wheel bolt pattern?
Ed
