3 members (JW51, Otto Skorzeny, 1 invisible), 112 guests, and 4 robots.
Topics128,269
Posts1,058,402
Members48,485
Hello All, I am modifying a 42 pickup which has the original drivetrain in it. I am in the planning phase. I wanted to sort out how I was going to mount an under the floor brake assembly on the frame rail since the original assembly is mounted directly to the transmission. I called ECI and Chassis Engineering, the only idea they had was to buy a universal one which welds in place. I am looking for a better idea, anyone set one up themselves and have a better idea?
Thanks in advance.
Bryan
Bryan Bauman
Have you thought of using a car master cylinder? My 40 chev master 85 used to have the brake cylinder mounted under the floor. I Think it was mounted to the frame.
All depends on how many modifications you are planning to make. If staying with a six you can keep your original bellhousing which has mounts for the master cyl/pedal assy. If going V8 you may want to use master cyl on the firewall with swing pedals.
1946 1/2-Ton Chevy
