7 members (Gdads51, Hugh63c10, moparguy, 32Fordpuchoptop, Hanks custodian, ShopRag, Ponchogl),
138
Mod | | | Forums66 Topics128,114 Posts1,056,283 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 23 New Guy | | New Guy Joined: Mar 2004 Posts: 23 | Hello All, I am modifying a 42 pickup which has the original drivetrain in it. I am in the planning phase. I wanted to sort out how I was going to mount an under the floor brake assembly on the frame rail since the original assembly is mounted directly to the transmission. I called ECI and Chassis Engineering, the only idea they had was to buy a universal one which welds in place. I am looking for a better idea, anyone set one up themselves and have a better idea? Thanks in advance. Bryan
Bryan Bauman
| | | | | Joined: Mar 2004 Posts: 25 Member | | Member Joined: Mar 2004 Posts: 25 | Have you thought of using a car master cylinder? My 40 chev master 85 used to have the brake cylinder mounted under the floor. I Think it was mounted to the frame. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | All depends on how many modifications you are planning to make. If staying with a six you can keep your original bellhousing which has mounts for the master cyl/pedal assy. If going V8 you may want to use master cyl on the firewall with swing pedals. | | |
