| | | Forums66 Topics128,077 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2017 Posts: 9 New Guy | | New Guy Joined: Dec 2017 Posts: 9 | In reassembling the front torque tube of my 3600 to the SM420 transmission, I found out that I forgot to add the cork seal to the torque tube ball cover (see link, thanks Denny Graham 2nd page 01W jpg). I didn't enjoy putting the tube assembly together the first time, and look forward less to doing it again. Would there be a problem slitting the cork, placing the slit to the top of the cover, and using a bit of permatex to re-seal it? Not trying to be lazy, just looking for an acceptable solution. Thanks https://pbase.com/dennygraham/driveline&page=2 | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I understand your pain but I think you will be disappointed. Having said that I would use RTV at the slit joint if I tried that. | | | | | Joined: Dec 2017 Posts: 9 New Guy | | New Guy Joined: Dec 2017 Posts: 9 | Well, I just bit the bullet and disassembled it and did it properly. Went better than I expected. This was my late fathers truck and he was a perfectionist in every sense of the word. I know that if he were here and heard me even talking about doing it any other way, I would have gotten an ear full. Thanks | | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | Good choice. I don't think the glued cork splice would have stood up to the movement that goes on in that assembly. It isn't much movement, but it can be abrupt.
