7 members (Southerntruck, jaycoop, Joe H, WICruiser, 2-Ton, 42465967, Shade Baby),
114
Mod | | | Forums66 Topics128,129 Posts1,056,362 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2018 Posts: 298 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 298 | Have a 1957 235 in my project 37 1/2 ton. Looking for a air cleaner that has 2 5/8 throat. Cannot seem to find one as most are all 2 1/4". Anyone have any answers to why this carb is bigger, or what year air cleaner would fit this? The carb is a Rochester B and has a auto choke. Thanks for any help with this. Bill
1937 GC
| | | | | Joined: Mar 2014 Posts: 4,501 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,501 | Sounds like a BC if it is auto choke. Does it have the center post for mounting the air cleaner? I'm away from my notes, but as I recall all those had a larger opening. When I used one of those I had to get an air cleaner from a Dodge to fit it...or at least that was the only one at the junk yard which fit. I've seen where you can get 2 5/8" adapters for some of the cheaper type air cleaners.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Jan 2018 Posts: 298 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 298 | Yes it has a 1 1/2" threaded 1/4" bolt sticking up. What year Dodge did you get it off.thanks Bill
1937 GC
| | | | | Joined: Aug 2018 Posts: 351 'Bolter | | 'Bolter Joined: Aug 2018 Posts: 351 | 2-5/8" is a standard air horn diamete for Stromberg 97s and Holley 94 carbs. You shouldn't have any issue finding an aftermarket filter for those. | | | | | Joined: Jul 2000 Posts: 2,195 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,195 | I made my own adapter so I could use an off the shelf 4 bbl air cleaner. I cut the front and back off a headlight bucket to make a funnel shaped adapter. The bolt needs to be replaced with a longer one.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Mar 2014 Posts: 4,501 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,501 | It was an air cleaner from a slant six...couldn't tell you the year. Lots of it had been stripped when I got the air filter. Nice thing about it is the elements are still available (FRAM) and $5.75 each on Amazon Prime...shipping included. If you want when I get home I'll send an image of it.
| | | | | Joined: Jan 2018 Posts: 298 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 298 | Yes a pic of it would be nice. Thanks
1937 GC
| | | | | Joined: Feb 2004 Posts: 29,811 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,811 | I believe the Rochester 2G series 2-barrels have an air horn diameter that's close to that size. There are untold thousands of those air cleaners decorating salvage yards around the country! Jerry
| | | | | Joined: Jan 2018 Posts: 298 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 298 | Thanks Jerry, I have searched my local scrap yard and looks to me like the first thing that's tore off the vehicles is the air cleaner. Will keep looking.
1937 GC
1937 GC
| | | | | Joined: Mar 2014 Posts: 4,501 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,501 | Here you go, Bill: https://tinyurl.com/y4srhmtqThis should be right for your carburetor and it has the PVC nipple as well (which could be plugged or used if you add PVC...which isn't a bad idea at all).
| | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | [url=https://shop.advanceautoparts.com/p/mr-gasket-deep-dish-air-cleaner-4354/6120369-p?c3nid=6120369-P&store_code=6171&c3ch=PLA&product_channel=local&adtype=pla&gclid=Cj0KCQjw4s7qBRCzARIsAImcAxamFwu2j99AOBTnroz7HmtExO9L8lC211Z958RSyxwt_TIihgQyEMgaAiCTEALw_wcB&gclsrc=aw.ds]I have these on my rochester b.[/url. List as 2 1/2 to 2 5/8. Auto zone and most parts houses carry them and also Amazon.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
